Issues displaying imported .dwg files
When importing a .dwg file only 1 layer is visible in Rhino in any view. All layers in Rhino are turned on as are all layers in the original .dwg file. All layers from the .dwg file are imported
Data from other layers has been imported but the curves are not displayed, with care some can be selected and appears as dotted lines, when deselected they disappear. All curves etc are found when selected for deletion with all blocks, hatches curves, dimensions and texts listed and quantified
Any thoughts on a remedy please?
Hi David,
Can you run SystemInfo in the command line and post the results.
I’m not seeing any issues with a quick test. Can you post a sample .dwg ?
Hi Japhy
Apologies for the delayed response
Felt rings 750.3dm (1.7 MB)
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Commercial, build 2023-08-09
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8Gb)
Computer platform: DESKTOP
Primary display: Parallels Display Adapter (WDDM) (Parallels) Memory: 4GB, Driver date: 8-14-2023 (M-D-Y).
> External USB display device with 6 adapter port(s)
Primary OpenGL: Parallels using AMD Radeon Pro 560X OpenGL Engine (Compat): Parallels and ATI Technologies Inc… OpenGL Ver: 4.1 ATI-4.14.1
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.1 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Parallels and ATI Technologies Inc.
Render version: 4.1
Shading Language: 4.10
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 4182698 KB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.32.23221.10241
Well, Parallels is not a supported system for Rhino for Windows.
Please post the .dwg so someone can test the import.
This is what I see in your .3dm:
Thanks for looking at the problem
Until recently for the previous 6+months Rhino 7 has performed perfectly with Parallels 18. There has been an upgrade to 19 which may have triggered the issue as may recent Rhino updates. I am reverting to Parallels 18 to see if that helps. I have deleted and reinstalled Rhino 7 it made no difference
Testing the .dwg file uploaded in Top view in all Display modes only dimension lines appear. In Perspective view zoomed out in all Display modes just the dimension lines appear. Zooming in all the curves then appear in all modes
Organic test.dwg (113.2 KB)
Model space objects read: 34, skipped: 9
Paper space objects read: 32, skipped: 0
Block definition objects read: 1344, skipped: 0
XRef objects read: 0, skipped: 0
I don’t know what those 9 “skipped” objects are.
This is what I see in Top view after opening (V7 latest SR, PC Windows 11):
In the file are 28 curves plus 6 radius dimensions (only in the figure at top right)
All the layouts appear to be blank except for the title blocks.
Rolling back to Parallels 18 seems to have sorted the problem
Many thanks for your help!!
