Import/open autocad files (dwg) in Rhino v7 - issues
Hi!
Suddenly, I am not able to open dwg files in rhino. When I open a DWG file “open with Rhino” I get an empty Rhino document. When I try to import a dwg file to Rhino I get "error importing file “[…]” in the rhino command field.
I’ve never had any issues with opening autocad files in Rhino before, and I really need it to work soon as possible.
Has anyone else had this problem and is there anything I can do about it?
Thank you, and merry christmas
In Options>Plug-ins, are the AutoCAD import and export modules enabled and loaded?
Perhaps the AutoCAD version is newer than is supported by Rhino?
Wow, that was a simple solution. The import module wasn’t ticked.
Thanks alot!
