Rhino 7.17 hangs up when I try to open this file: https://terra-1-g.djicdn.com/b20074248eff4b7f957d0f1a5ab29253/M300RTK_3D_Model.stp
The file size is 298MB.
Hello- there are 34 million entities, I expect it will take some time, step is a text format after all too. I am still wating…
And if you’re elected to join surfaces it will take even longer
That too…
On my Mac I can see continuous progress update, though, so that helps
(this is with joining of surfaces disabled)
And after ~5 minutes without the joining
Yeah, on windows it starts off with that but stops reporting after a while - however it does open.
Maybe something to report? The Mac progress was active all the way until the end.
Yep, I will see if I can repeat.
A post was split to a new topic: Trouble loading Bongo
