Blocking Plug-In STEP import
Hi everyone,
I cannot open any STP or STEP files in my Rhino7 program. When I do attempt to open a file, no objects load and I receive this text in this order…
‘Blocking plug-in Renderer Development Kit UI’
‘Blocking plug-in Displacement’
‘Blocking plug-in STEP Import’
I have tried searching for solutions and cannot find anything matching my issue. How can I open these STP files? Only recently I cannot open these files. Any suggestions?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Commercial, build 2022-04-12
License details: Stand-Alone
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 12-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.91
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-13-2021
Driver Version: 30.0.14.7291
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\sesa638551\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.2.0.0\KeyShot10RhinoPlugin\Rhino 7\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.2.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
Thanks.
When you run PlugInManager, are those plug-ins enabled?
Make sure these 3 plug-ins are Enabled and Loaded:
Those three were the only three unselected. Should they be selected and installed?
And when I say those three I mean the Renderer Development Kit UI, Displacement, and STEP Import.
Check the enable box of all three and either restart Rhino, or right-click on each one and choose the Load plug-in option.
All three should then show “yes” as loaded.
Then try your import again.
Ah finally that worked! Wonderful, thank you for sharing your knowledge!
