Hi, I am a non-english speaker so first of all sorry for my bad english and lack of searching ability to avoid double posting of similar question.
So, I do have a problem with starting Rhino 6.
It just won’t open both Rhino 6 and Rhino6 in safe mode. (ran as administrator).
Not even an single error message shows up. Whenever i tried to start it, nothing seems to show up in Windows Task Manager.
I checked,
Opened the Registry Editor however don’t have ‘global’ folder In the registry, under HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0
I only have ‘install’ -
Updated NVIDIA driver (GTX 1060) to 442.50 and Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1903 (February 27, 2020-KB4537572)
Here are the specs
Microsoft Windows 10 Home (64bit)
1909 (10.0.18363)
Intel® Core™ i7-8750H CPU @ 2.20GHz
NVIDIA GeForce GTX 1060 / Version 26.21.14.4250 (2/24/2020)
Resolution
1920 x 1080
Bits Per Pixel
32
Number of Colors
4294967296
Refresh Rate - Current
60 Hz
Refresh Rate - Maximum
75 Hz
Refresh Rate - Minimum
50 Hz
Adapter DAC Type
Integrated RAMDAC
Adapter RAM
4.00 GB
Availability
Running at full power
Status
This device is working properly.
Intel® UHD Graphics 630 / Version 25.20.100.6577 (2/7/2019)
Resolution
1920 x 1080
Bits Per Pixel
32
Number of Colors
4294967296
59 Hz
0 Hz
Adapter DAC Type
Internal
Adapter RAM
1.00 GB
Availability
Status
16 GB RAM
Physical Memory - Total
16 GB
Physical Memory - Available
10.26 GB
Virtual Memory - Total
18.28 GB
Virtual Memory - Available
10.61 GB
Page File
C:\pagefile.sys
Page File Space
2.38 GB
Is there anything I can do with this problem?
Thank you in advance.
