dan
(Dan)
1
Rhino 6 SR7 Release Candidate 1 (6.7.18177) is now available.
To get it, subscribe to the Release Candidate update stream.
New in SR7 RC1:
Performance Problem:
- Grasshopper: Components: QuickGraph needs to throttle the graph path density. (RH-46540)
Feature:
- Grasshopper: Components: GraphMapper needs to handle nulls and NaNs. (RH-46582)
Crash:
- Grasshopper:
- Avoid and repair nested groups in Grasshopper. (RH-46681)
- Stackoverflow crash when opening GH file. (RH-46653)
Bug:
- Annotation: Leader: Text orientation Incorrect when leader rotated to 270 degrees (RH-46474)
- Display: TestMooCow broken in current WIP (RH-37073)
- Explode: Linked block definitions missing meta data (RH-30289)
- Grasshopper: Disabled Symbol Display components still preview (RH-46609)
- Grasshopper: Components: Colour Addition broken (RH-46528)
- No Subsystem: SolidWorks imported objects flip when re-opening a file. (RH-46500)
- PackageManager: Yak dialog shows up on a second, detached display (RH-46286)
- Rendering: Stripped Textures (RH-46509)
- Selection: Mesh ngons can not be removed from selection (RH-46560)
Enhancement:
- Grasshopper: Components: Add internal sorting to QuickGraph. (RH-46541)
dan
(Dan)
4
Rhino 6 SR7 Release Candidate 2 (6.7.18183) is now available.
New in SR7 RC2:
Regression:
- SDK: Python: rhinoscriptsyntax Layer methods deleting layer user data (RH-46260)
Bug:
- Alerter: Plugin fails to load in V6 (RH-46325)
- Annotation: No actual value shown for dimensions in Properties (RH-46670)
- Annotation: Leader: Changing leader text size from ObjProps doesn’t work right (RH-46667)
- Block: Objects in the wrong location in 6.7 (RH-46905)
- Cycles: Raytraced mode doesn’t use WCS mapping properly on extrusion objects (RH-46717)
- Display: Extra hatches (RH-46950)
- Help: Loose option in OffsetMultiple command of Online Help document (RH-46973)
- Offset: Loose=Yes should not hide Cap option (RH-46969)
- Rendering: Materials: Changing material to custom blanks material settings (RH-46747)
- SDK: Python: rs.ExpandLayer throws error (RH-46999)
- SDK: RhinoCommon:
- Premature Garbage Collection (RH-46970)
- TextureMapping missing method to create Planar UVW mapping (RH-46993)
- ToNURBS: Missing patches at vertices with corner tags. (RH-47003)
Crash:
- No Subsystem: opennurbs!ON_3dmConstructionPlane::ON_3dmConstructionPlane – Access Denied (RH-46924)
dan
(Dan)
5
Rhino 6 SR7 Release Candidate 3 (6.7.18190) is now available.
New in SR7 RC3:
Bug:
- Annotation: Linetype: Create ETO Linetype Modal Dialog (RH-46484)
- Display:
- Block instance display color unstable (RH-45093)
- Detail print color display ignored in blocks (RH-47035)
- File IO:
- IGES Export Color Option Default (RH-46878)
- STEP import missing surfaces (RH-35624)
- Step import - Ugly surface that other products can repair (RH-36106)
- Surfaces trimmed incorrectly reading DWG file (RH-46761)
- Guides: Should not be copied with objects to another model (RH-46776)
- InfinitePLane: Show the plane right away (RH-46959)
- Print: Clean up paper sizes (RH-46464)
- Rendering: Materials: Disappear (RH-46825)
- SDK: GHPython: prevent the external scope from evaluating at every repetition (RH-47124)
- SelChain: SelChain, SelColor and script runner commands (RH-46995)
- Toolbar: Error message when loading disabled plug-in RUI file (RH-47126)
- Tutorials: Confusing links in Help (RH-46980)
Crash:
- Cycles: IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs. (RH-47041)
- SDK: RhinoCommon: tl!TL_SortPlanarCurves – Access Denied (RH-47199)
brian
(Brian Gillespie)
6
Rhino 6 SR7 Release Candidate 4 (6.7.18193) is now available.
New in SR7 RC4:
Bug:
- Annotation: Styles: Dimension scaling ignored from V5 files. (RH-46535)
- BlendSrf: Request to make blend to singular surfaces (RH-15456)
- Block: Can’t preview Print Color In Block Geometry. (RH-44536)
