Rhino 6 SR7 (6.7.18199) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Crashes Fixed:
- Cycles: IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs. (RH-47041)
- Display: ViewCaptureToFile Command: RhinoCore!CompileShader – Access Denied (RH-46867)
- No Subsystem: opennurbs!ON_3dmConstructionPlane::ON_3dmConstructionPlane – Access Denied (RH-46924)
- SDK: RhinoCommon: tl!TL_SortPlanarCurves – Access Denied (RH-47199)
Bugs Fixed:
- Alerter: Plugin fails to load in V6 (RH-46325)
- Annotation: No actual value shown for dimensions in Properties (RH-46670)
- Annotation: Leader: Changing leader text size from ObjProps doesn’t work right (RH-46667)
- Annotation: Linetype: Create ETO Linetype Modal Dialog (RH-46484)
- Annotation: Styles: DImension scaling ignored from V5 files. (RH-46535)
- BlendSrf: Request to make blend to singular surfaces (RH-15456)
- Block:
- Cycles: Raytraced mode doesn’t use WCS mapping properly on extrusion objects (RH-46717)
- Display:
- File IO:
- Guides: Should not be copied with objects to another model (RH-46776)
- Help: Loose option in OffsetMultiple command of Online Help document (RH-46973)
- InfinitePLane: Show the plane right away (RH-46959)
- Offset: Loose=Yes should not hide Cap option (RH-46969)
- Print:
- Rendering: Materials:
- SDK: GHPython: prevent the external scope from evaluating at every repetition (RH-47124)
- SDK: Python: rs.ExpandLayer throws error (RH-46999)
- SDK: RhinoCommon:
- SelChain: SelChain, SelColor and script runner commands (RH-46995)
- ToNURBS: Missing patches at vertices with corner tags. (RH-47003)
- Toolbar:
- Tutorials: Confusing links in Help (RH-46980)
Regressions Fixed:
- SDK: Python: rhinoscriptsyntax Layer methods deleting layer user data (RH-46260)
