Rhino 6 SR5 (6.5.18149) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
New in SR5:
Regressions Fixed:
- Options: Layer import bug (RH-45955)
Crashes Fixed:
- Annotation: Leader: Win32Exception: Fehler beim Erstellen des Fensterhandles. (Error creating window handle) (RH-46046)
- Geometry Core: opennurbs!ON_Brep::PrevTrim – Access Denied (MERGE) (RH-46101)
- Layer: RhinoCore!CLayerManagerListCtrl::OnPopupWorksessionSetActiveModel – Access Denied (RH-46054)
- No Subsystem: MILERR_WIN32ERROR (Exception from HRESULT: 0x88980003)(MERGE) (RH-45882)
Enhancements:
- Grasshopper: MRU Tiles show full filename. (RH-42716)
Usability Problems Fixed:
- Interface: button bitmap editor is not working in v6 (RH-45949)
Bugs Fixed:
- Annotation:
- Dimensions made with plain user text from reading old files don’t display any text (RH-45938)
- Make a way to turn off automatic annotation history recording. (RH-45895)
- Set Layout scaling off reading v4 files (RH-45937)
- Text from V4 files displayed in the wrong location (RH-45939)
- Undisplayed text not saved to V5 (RH-45987)
- Annotation: DimAngular: DimAngles are on the CPlane (RH-45722)
- Annotation: Text: Applying
boldby clicking the Bold button doesn’t work anymore (RH-45918) - AutoSave: No Autosave on re-open (RH-46138)
- BackgroundBitmap: Embedded Background bitmap not displaying when file reopened (RH-45959)
- BoxEdit: Issues in Rhino 6 (RH-46010)
- Cycles: Setting Samples count to 0 crashes Rhino when switching to Raytraced view. (RH-46086)
- Display:
- Eto: Eto" Method not found GetEtoWindow() (RH-45933)
- File IO: Obj export still has material problems (RH-45415)
- Fillet: On wrong segments (RH-46073)
- Grasshopper: Groups are missing in Custom Display Render pipeline. (RH-45900)
- Grasshopper: Components:
- Help: Object snaps with mesh wires? (RH-45997)
- Localization: Localization error (italian) in 6 SR 5 RC 3 (RH-46277)
- Make2D:
- No Subsystem: :OnClose (RH-46177)
- Print: Blocks are offset (RH-44585)
- RDK:
- ShowNotifications: NotificationModal crashes when using the updater (RH-45789)
- SmartTrack: Mid & Smarttrack smart points (RH-45833)
- Undo: Error about Make2d - the Group option in the Make2d will delay the run time (RH-43205)
- ViewCaptureToFile: ViewCaptureToFile - “Unit” option not working in non-english Rhino (RH-45760)
