brian
(Brian Gillespie)
1
Rhino 6 Service Release 2 is now available. Rhino 6 will automatically update to SR2 over the next several days.
New in SR2 RC1:
Bug Fixes:
- ApplyEdgeSoftening: Edge softening doesn’t keep up with geometry changes (RH-43781)
- Cycles: Multiple importance sampling control together with caustics control (RH-40088)
- Displacement: Doesn’t work with plastic bump textures (RH-38635)
- Display: Automatic ground plane elevation ignores objects with custom render meshes (RH-43695)
- Display: OpenGL 3.3: OpenGL error when drag&drop material onto scene when ClippingPlane exists. (RH-39173)
- ExtractIsocurve: Not scriptable (RH-43868)
- File IO:
- NamedView: Problem renaming Named Views (RH-43853)
- Offset: Fails in V6 (RH-43809)
- RDK:
- Can’t type into Bitmap Texture combo box (RH-43845)
- Float field does not respect limits in the Content Automatic UI (RH-43796)
- ImageFile Datasource (Bitmap texture & HDR texture) (RH-43823)
- Rendering: Materials: Resample texture does not work with simple bumps in child slot (RH-43830)
- SDK: RhinoCommon:
- Add function to fit circle from points (RH-43626)
- Mesh.CreatePatch incorrectly requires points (RH-43531)
- RenderContent Icon functions leak memory (RH-43957)
- SDK: RhinoScript: External Access via COM Broken (RH-43783)
- Silhouette: Draft Angle misses nurbs surfaces (RH-41972)
- Subobject Selection: First move creates bad mesh (RH-43827)
- UDT: ConstrainNormal & direction (RH-43944)
Enhancement:
- SDK: RhinoCommon: Custom offset vector for Mesh.Offset (RH-43825)
Please report any problems in this forum. Thanks!
brian
(Brian Gillespie)
4
Service Release 2 Release Candidate 2 (6.2.18043.22301) was just released
Crashes fixed:
- New: Crashing after New file if render plugin has been changed (RH-43560)
Bugs fixed:
- ApplyEdgeSoftening: Dragging edge softened objects is generating new meshes and is slow (RH-37154)
- BlendEdge: Ugly rails (RH-24660)
- BlockEdit: OK Cancel should be on the frame (RH-44038)
- BoundingBox: Sub-object bounding box (RH-43945)
- Display:
- Instanced textures don’t update in Rendered until material is adjusted (RH-42889)
- Very slow when rendering many mapping meshes (e.g. 100 spheres) (RH-37548)
- File IO:
- Text in this model does not export to DWG properly (RH-43467)
- Text is offset after save to dwg and import of this file (RH-43466)
- FilletEdge:
- Almost makes a clean fillet (RH-23606)
- Distance between rails filletedge doesn’t extend,trim and join (RH-28599)
- Gappy - 4 Edge Tan (RH-5780)
- Localization: Add lights from light panel fails in localized Rhino (RH-43882)
- Move: Vertical - from point to Origin (RH-36070)
- PointDeviation: Broken in 6.1 (RH-43262)
- RDK:
- Dragging material from material library over viewport causes OpenGL error in Core Profile (RH-39087)
- SetViewFocusDistance unknown command in German version (RH-44000)
- Rendering:
- Ground plane material isn’t used in Rendered display (RH-43152)
- Render Window channel toggles do not stick (RH-4320)
- Bump texture preview is all black when converting material from Plastic to Custom (RH-37132)
- File dialog for selecting textures is “old” (RH-22156)
- Library thumbnails don’t match what is rendered in Material thumbnail (RH-39000)
- SDK: RhinoCommon:
- DrawSprite Bug (RH-43751)
- Wrap ON_ModelComponent::DeletedName in RhinoCommon (RH-43947)
- Toolbar: Add raytraced to New in V6 (RH-43655)
- UDT: Flow messy to vertical curves example (RH-32184)
brian
(Brian Gillespie)
5
Service Release 2 Release Candidate 3 (6.2.18051.09541) is now available.
Bugs fixed:
- Annotation: Text: Type in the font list (RH-43924)
- BackgroundBitmap: BackgroundBitmap is back! (RH-43797)
- BoxEdit: Units precision is ignored (RH-43024)
- Cycles: Flaked Car Paint (DEV) material doesn’t toggle off (RH-44053)
- ExtrudeCrv: Hide SplitAtTangents when UseExtrusions is set Extrusion (RH-43666)
- File IO:
- 3DS files from Rhino won’t open in ArchICAD (RH-30451)
- 3DS not imported correctly (RH-30668)
- HookUp DataKit SW import lib 2018.1 (RH-43442)
- FilletEdge: Misses - example (RH-1345)
- Join: Curve join results in invalid polycurve. (RH-43661)
- Layer: Sorting unlike V5 (RH-41224)
- RDK: Popped-out thumbnail list is borked (RH-44092)
- SDK: 6.1 SDK installer breaks Visual Studio plug-in wizard (RH-44063)
Cosmetic bugs fixed:
- Toolbar: Icon for Raytraced mode in toolbar (RH-42953)
brian
(Brian Gillespie)
6
Service Release 2 Release Candidate 4 (6.2.18054.19571) is now available
Crashes fixed:
Bugs fixed:
- Cycles: Early view rotate issue (RH-44081)
- Displacement: Causes assert on adding material (RH-43989)
- File IO:
- STEP import misplaces block instance (RH-44280)
- STEP import takes a long time on file with large number of blocks (RH-42682)
- Help: Command names can’t be sorted alphabetically in command_list.htm (RH-43180)
- Offset: OffsetMultiple - Crvs Ignored (RH-43705)
- Panels: Tearing off a panel creates a second key/value in the m_instance_dictionary of PanelContainers. (RH-43343)
- Rhino Installer Engine: rhiexec fails to recognize 6.2 as valid RhinoVersion value (RH-44217)
Regressions Fixed:
- NamedView: Names echos unknown command in command line (RH-44161)
