Rhino 6 SR12 (6.12.19029) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Cycles: Matte materials raytrace all black using cubin files compiled with CUDA 10 (RH-49636)
- Delete: Deleting lots of history objects and parents is slow (RH-49741)
- Display:
- EdgeSrf: Leaks memory (RH-49971)
- File IO: Error message on cancel (RH-49871)
- Localization:
- Make2D:
- No Subsystem: Floating previews are white while resizing (RH-49955)
- Print: Picture not Printing with Detail Clipping to Rhino PDF (RH-49079)
- Purge: Hatch in block changes pattern on purge, save and reopen (RH-49808)
- RDK:
- RectangularLight: Pre-pick manipulation of rectangular light doesn’t allow snapping to corners (RH-49551)
- Rendering:
- Rendering: Materials: Changes to texture channel material settings fail to update in Rendered and Raytraced display modes (RH-50467)
- SDK: Python: Update samples to use != (RH-49811)
- SDK: RhinoCommon: Wish - Add linked or linked/embedded instance definition to File3dm (RH-49968)
- SelectionFilter: Sub-objects checkbox visibility (or general case) sizing bug (RH-49817)
- ShowEdges: Zoom action improvement (RH-49928)
- Subobject Selection: Select one menu has wrong texts (RH-49986)
Crashes Fixed:
- Cycles:
- No Subsystem: Commands.ViewModels.MeshRepairWizardViewModel.UpdateCheckStatesAndLog () (RH-49882)
- Rendering: rdk!ShrinkDataInt – Access Denied (RH-49175)
Enhancements:
- Explode: Exploding linked block makes all layers visible (RH-49038)
- Snapshot:
Features Added:
- SDK: RhinoCommon: Have a way to tell an ObjectPropertiesPage (or other panel hosts) when they are closed/disposed (RH-49990)
