Rhino 6 Service Release 14 Available
Rhino 6 SR14 (6.14.19118) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
  • Annotation: Font in dropdown changes to Arial when highlighting text using Din-PRO font (RH-50459)
  • Annotation: DimLinear: History broken on Extrusion objects (RH-50905)
  • Annotation: Leader: Break history on leader text modification (RH-51081)
  • Arc: Doesn’t respect coordinate input (RH-50674)
  • BlendSrf: No Zebra on chained edges (RH-50790)
  • Cycles: Texture images are read in flipped through Cycles XML (RH-51358)
  • Display:
    • Decals don’t have mipmapping enabled (RH-50908)
    • Display mode causes block selection to go odd (RH-50649)
    • Technical shows lines from off-in-detail layers (RH-50008)
    • Text quits displaying after lots of view changes (RH-50854)
  • File IO:
    • Dialog hidden on Open from Explorer (RH-48713)
    • Preserve Units does not (RH-50835)
    • STEP explosion (RH-51083)
    • SketchUp materials come in incorrectly in nested components (RH-51558)
    • Some materials that have names in Sketchup get set to nothing in Rhino (RH-51571)
  • Grasshopper: Parallel computing with Point in Brep Component crashing Rhino (RH-51201)
  • Gumball: Does not accepts scaling in units, if scale node has been adjusted (RH-51170)
  • Help: F1 does not open Circle help (RH-51106)
  • Licensing: Cloud Zoo: Cloud Zoo hang-up (RH-51259)
  • Localization: Unlocalized command in German Rhino (RH-50786)
  • MacroEditor: Opens Help web page (RH-51169)
  • MatchCrvDir: Too flippy (RH-50653)
  • ModifyRadius: Current radius number format (RH-50637)
  • NamedView: Dragging a Named View Widget does not cause a OnEvent call (RH-50995)
  • No Subsystem: In-place material editor displays texture after pasting (RH-50878)
  • OpenNURBS:
  • Print: Draw Order not consistent with print output (RH-50792)
  • Properties:
    • Dimension icon becomes blank (RH-51272)
    • Text and gumball armwrestling (RH-47379)
  • RDK: Ground Plane dialog shows a tip when it shouldn’t (RH-50772)
  • Rendering: Materials: The BUMP texture does not open (RH-50706)
  • RoundHole: Stops working after first hole (RH-50626)
  • SDK: DisplayMode properties changed by scripts revert back on Gumball toggle and other actions (RH-51112)
  • SDK: RhinoCommon:
    • RhinoDoc.WriteFile should pay attention for file extension (RH-51091)
    • SweepOneRail.PerformSweep failure (RH-50636)
  • SDK: RhinoScript: Rhino.AddText fails on strings with backslashes (RH-50611)
  • Selection: Pre-selected object gets semi-unselected during Trim (RH-50851)
  • SetUserText: Attribute user text from Properties (RH-51298)
  • Snapshot: Requires BonusTools plug-in to be loaded before it will show layer states (RH-48962)
  • Toolbar: Icons are wrong or wrong size (RH-50996)
  • UDT:
  • UserText: Fragile link between Attribute User Text - Text Field - Object Name and Object Name (RH-51172)
  • ViewCaptureToFile: Results in DARK output when using a custom Technical display mode (RH-50740)
Crashes Fixed:
  • Cycles: Crash with linear lights in Raytraced (RH-50809)
  • No Subsystem:
    • :OnEraseBkgnd – Access Denied (RH-50798)
    • mfc140u!mfc140u – Access Denied (RH-50932)
  • PackageManager: System.ThrowHelper.ThrowArgumentOutOfRangeException (ExceptionArgument argument, ExceptionResource resource) (RH-50507)
  • Project: opennurbs!ON_Curve::EvPoint – Access Denied (RH-50929)
  • RDK: Rhino crashes on exit after pasting a deleted material (RH-50759)
  • SDK: mfc140u!mfc140u – Access Denied (RH-51067)
  • SDK: Python: Crash on MatchAtrributes (RH-50362)
  • SDK: RhinoCommon:
    • Crash in Brep Curve Intersection component (RH-51517)
    • Rhino crashes when loading Octane. (RH-52114)
Regression:
  • Annotation: Text: Cannot change font size in text editor (RH-51527)
  • Display: “Shade-highlight selected” doesn’t work on objects inside blocks (RH-50700)
  • Make2D: Clipping plane cutting into box in Top view produces no result from Make2D (RH-51626)
  • NamedView: Cannot transform control points of Named View Widget (RH-50696)
  • No Subsystem: :Impl – Access Denied (RH-49602)
SDK Enhancement:
  • Rendering: Wwitching material type doesn’t show UI (RH-49764)
  • SDK: RhinoCommon: Documentation for Rhino.Render.RealtimeDisplayMode (RH-32019)
Tasks Completed:
  • OpenNURBS: Release new public opennurbs from 6.14 (RH-51765)
Rhino 6 SR14 Hot Fix 1 (6.14.19127) is now available
Bugs Fixed:
  • Crash: Rhino goes into infinite loop opening file (RH-52362)
This service release hot fix is distributed just like any other service release. It is called a hot fix because it contains one fix for a critical issue.
@brian Does SRC Version 6 SR15 (6.15.19133.20241, 5/13/2019) include the fix or should I force an installation of SR14 Hot Fix 1 (6.14.19127)? Check for updates is returning that I have the most recent version.
Hi David - you can always run the GetIssueState command to find out if a certain fix is in the build that you are running.
Command: GetIssueState
Issue Id: “RH-52362”
RH-52362 (Announce): git commit in this build = False
However, as you see, in this specific case, this currently returns False because the issue hasn’t been closed yet. It does say Announce, which is a state after the issue has been tested and found to be fixed.
HTH
w
The latest SR15 RC includes this fix.
