Rhino 6 Service Release 19 Now Available
Rhino 6 SR19 (6.19.19295) Is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
  • Annotation: DimLinear: With no Draw forward correction, Dimension text may orient wrong (RH-54734)
  • Curve-surface intersection: Can't find the intersection (RH-3301)
  • File IO:
    • V6 can’t read Solidworks file (RH-54469)
    • Text doesn’t read in from this PDF file (RH-54612)
    • Revolve goes bad in BlockEdit (RH-54749)
    • Reading Sketchup file: Some meshes have ununified normals (RH-54823)
    • Lights exported to different positions (RH-54862)
    • “Map Rhino Z to FBX Y” does not affect lights (RH-54882)
    • Text rotates improperly when written to DWG (RH-54902)* Grasshopper: Grasshopper wrongly blames GhPython (RH-53303)
  • ImportPreferences: Typo in Tool Palettes (RH-54803)
  • Join: Join - Preselected surface edge cannot be joined to other surface edges (RH-54533)
  • Lights: Light power of 100% is reduce to 1% when 3dm is opened on Windows (RH-54695)
  • Localization: MeshRepair shows English (RH-52799)
  • Print: Surface edge color incorrect when printing selected objects in shaded mode (RH-38049)
  • PrintPreview: Linetypes are not displayed at correct scale (RH-54532)
  • SDK: Make a RhinoCommon function for RhinoGetPointInsideSolidBrep (RH-54687)
  • Subobject Selection: More feedback for sub-object selection (RH-54128)
Cosmetics:
  • PointDeviation: PointDeviation dialog - labels don't align with lines (RH-54483)
Crashes Fixed:
  • : opennurbs!ON_HistoryRecord::`RTTI Complete Object Locator' – Access Denied (MERGE) (RH-54599)
  • Display: RhinoCore!CTextureFileNotifier::AddFile – MERGE (RH-54376)
  • WeldVertices: RhinoCore!TopVertexWelder – Access Denied (RH-54996)
Regressions Fixed:
  • Display: Silhouettes missing in 6.18 (RH-55080)
SDK Enhancement:
  • SDK:
    • Exposing ON_Brep::MatchTrimEnds in RhinoCommon (RH-54629)
    • Make a C++ SDK function to find a point inside a solid BREP (RH-54686)
Tasks Completed:
  • Grasshopper: Backport TestCodeEditor improvements to 6.x (RH-54223)
Usability Problems Fixed:
  • Drag: Can't drag a whole polyline when it is already selected (RH-54726)
Mac-Only Changes
Bugs Fixed:
    • Gumball settings don’t work properly in V6. (RH-55057)
    • Render Contents inaccessible on macOS Catalina (RH-55137)* Annotation: Text: Add more Helvetica Neue Quartets to Mac installed font list (RH-53430)
  • ApplyDisplacement: Render mesh disappear (RH-54466)
  • AutoSave: Rhino freeze (RH-54268)
  • BlendCrv: BlendCrv Edit option is broken (RH-54419)
  • BlockEdit: Make the current model active after editing a linked block (RH-52373)
  • Developer Tools: Update CI and bootstrap versions (RH-54689)
  • Display: Render meshes far from origin have artifacts (RH-54640)
  • DragMode:
    • DragMode broken on V6 for MAC (RH-54650)
    • CPlane option not removing the previous tooltip (RH-54850)* EditPythonScript:
    • Editor window needs a minimum size (RH-54445)
    • Needs to support Dark Mode (RH-54446)
    • Window should not minimize and maximize during run (RH-54447)
    • Bottom API documentation section area needs minimum height (RH-54449)* Grasshopper:
    • Search popup contrast poor in Dark Mode (RH-54679)
    • User Object Properties dialog does not open icon browser (RH-54693)
    • Cursor does not change when component is selected from the component palettes (RH-54740)
    • Rhino doesn’t hide/minimise with Grasshopper open (RH-54915)
    • Conflicting plugins or user objects causes no components to load (RH-55183)* Gumball: Arc arrows disappear on mouse movement (RH-47103)
  • Lasso: Nested Lasso selects subobjects when whole objects are expected (RH-42830)
  • Length:
    • Nested Length command does not work properly (RH-54744)
    • Nested command does not change the cross cursor to an arrow (RH-54816)* Localization: Nesting the Length, Radius, and Distance commands doesn't work in localized (Asian?) versions. (RH-40858)
  • Offset: Length, Radius and Distance don't work on Mac (RH-40859)
  • Preferences:
    • Panning with middle mouse button (RH-54717)
    • Fails to import custom tool sets (RH-54733)* Radius: Nested Radius command does not work properly (RH-54743)
  • Rebuild: Make the numbers work out (RH-47425)
  • ReduceMesh:
    • Adding locked mesh points doesn’t work (RH-40084)
    • ESC key doesn’t remove locked point display (RH-40086)* Rendering: Materials: Color mask setting is incorrectly labeled on Mac (RH-54333)
  • Rendering: Realtime SDK: Raytraced Mode HUD and its icons too small (RH-53497)
  • RotateView: UI for new viewport rotation option needed (RH-39598)
  • SDK: RhinoCommon: Calling PushPickButton from inside a ShowSemiModal Eto dialog does not work properly (RH-54477)
  • Selection: SelID fails nested on Mac (RH-49457)
  • SelectionFilter: Command-line filter "Edge" is unknown (RH-45951)
  • Settings: "Dead" button on the Settings dialog (RH-51589)
  • Sidebars: Unfinished Selection Filter features appear in right-hand sidebar in 6.19 (RH-55236)
  • Split: Command line cannot accept Sel commands (RH-38056)
  • Subobject Selection: Subcurves can't be extruded with Gumball (RH-42036)
Cosmetics:
  • EditPythonScript: Run button needs Rhino for Mac styling (RH-54448)
  • UI Cleanup: Curvature graph dialog on Mac (RH-52396)
Crashes Fixed:
  • AutoSave: Rhino freezes during Autosave when embedding Mono 6.0.0 (RH-54290)
  • Grasshopper: Object reference not set to an instance of an object (RH-54253)
  • Groundplane: GroundPlane panel causes crash on macOS Catalina (RH-55226)
  • New: Crash after New Document creation on macOS Catalina (RH-55141)
  • RDK: Crash when attempting to use ToMeshArray() on a RenderPrimitiveList (RH-44411)
Features Added:
  • LayoutWorkspace: No way to display Osnap toolbar in Layout editor (RH-52543)
  • SelectionFilter: Can't type nested commands on Mac (RH-45950)
Incomplete Port:
  • CursorTooltip: Cursor tool tips offset (RH-51573)
  • Grasshopper: GH Window disappears when Rhino isn't the active application (RH-50695)
  • Preferences: Missing control point styles on Mac (RH-53848)
  • SDK: GHPython: Code completion / auto indent in GhPython on macOS (RH-54435)
  • UndoSelected: Not yet implemented (RH-52440)
Regressions Fixed:
  • ShowSelected: SelColor in hidden objects requires new selection - not so in RH5 (RH-46716)
  • Gumball: Pressing Space in value entry does not function as Enter (RH-36510)
Windows-Only Changes
Bugs Fixed:
  • RhinoStart: Using /runscript command line parameter converts script to lower case (RH-54900)
Crashes Fixed:
  • Grasshopper: Components: Populate Geometry crash (RH-53872)
Regressions Fixed:
  • Keyboard Shortcuts: Ctrl-V change ignored (RH-52277)
Tasks Completed:
  • Options: Move Control Point Style above Visibility (RH-54813)
