Rhino 6 SR9 (6.9.18271) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Crashes Fixed:
- Annotation: Rhino.Geometry.TextEntity (RH-48116)
- Annotation: Hatch: opennurbs!ON_Curve::PointAtStart(MERGE) (RH-48087)
- CrashDump: .NET crash during Rhino exit on Windows 10, 1803, build 17134.81 (RH-46531)
- Cycles: Crash when switching away from Raytraced (RH-48355)
- Display: :GetDepthBuffer – Access Denied (MERGE) (RH-48359)
- Grasshopper: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. (RH-48322)
- Grasshopper: Components: GH - dot display Crash (RH-46250)
- Layer: RhinoCore!CLayerManagerListCtrl::OnPopupWorksessionSetActiveModel – Access Denied (RH-46054)
- No Subsystem:
- ProjectToCPlane: Access Denied (RH-48534)
- Properties: System.Reflection.TargetInvocationException: Rhino.Runtime.CommonObject.ConstPointer () (RH-48552)
- Rendering: Realtime SDK: Crash while exiting Rhino with a SampleRealtimeRenderer.rhp loaded (RH-46405)
- SDK: RhinoCommon:
- InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created. (RH-48360)
- Object reference not set… ETO. (MERGE) (RH-48366)
- System.InvalidOperationException: Nelze volat funkci Invoke nebo BeginInvoke pro ovládací prvek, dokud není vytvořen popisovač okna. (RH-48327)
- UNKNOWN!Commands.UI.AnnotationStyles.StyleViewModel.UpdateStyleTable – Access Denied (RH-48364)
- Zoom: Access Denied (RH-48514)
Bugs Fixed:
- Annotation:
- Annotation: DimAngular:
- Annotation: DimLinear: Dimension Length factor (RH-47566)
- Annotation: Text:
- ArcTTR: Tangent Radius Tangent in v6 (RH-48076)
- BlendSrf: History error (RH-48042)
- Block: No selection color on multiple blocks (RH-46074)
- Build Process: Submodule not being updated by localization process (RH-48104)
- Crash Processing System:
- Cycles: Texture rotation off (RH-45995)
- Dir: Direction analysis watcher never deleted (RH-48053)
- Display: SetObjectDisplayMode - Technical & Artistic (RH-47167)
- Faro: digitize_Faro.rhp “Preparing for first use” every time Rhino for Windows 6.x WIP starts. (RH-47815)
- File IO:
- Grasshopper: Components: Error about Integer component (RH-47829)
- Installer:
- 6.9 RC5 prompts “Enter your license key” (RH-48716)
- 6.9 and 6.10 launches without toolbars, without using the saved rui and forces a reload of all plugins with some failing (RH-48433)
- After installing 6.9 upgrade from 6.8, the language installer does not run (RH-48652)
- Options ignored during deployment (RH-44423)
- Rhino 6.9.18268 changed my installation path (RH-48714)
- Script install of 6.6 using Zoo, update to 6.7, forgets Zoo (RH-47603)
- Scripted Installer update from 6.8 to 6.9 loses license configuration (RH-48673)
- Scripted update loses Zoo config (RH-48667)
- The Rhino installer for 6.8 does not push install the Zoo server name correctly. (RH-48179)
- Localization:
- Make2D:
- PluginManager: Rhino says Faro Digitizer plugin needs to be updated, but provides little information on what to do. (RH-48160)
- Print: Printing a layout should default to the layout’s paper size (RH-47941)
- Properties: UserText properties page goes blank when using Gumball (RH-48578)
- RDK:
- Rebuild: Pops up several identical warnings (RH-47721)
- Rendering: Materials:
- Rendering: Texture Mapping:
- RhinoStart: rhps do not load (RH-48377)
- SDK: RhinoCommon: File3dm.GetPreviewImage only works in Rhino (RH-45096)
- Templates:
- Update System: Missing toolbars after update (RH-48389)
- WireCut: Typos and tune ups (RH-42266)
Regressions Fixed:
- Properties: Radial and Diameter Dimension Show Invalid Overrides (RH-47540)
