Rhino 6 SR6 (6.6.18177) is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
New in SR6:
Enhancement:
- Annotation: DimOrdinate: Needs Update Option (RH-46154)
Crashes:
- Annotation: Report of corrupt DimStyles when reading V5 files. (RH-43943)
- No Subsystem: opennurbs!ON_Geometry::GetBoundingBox – Access Denied(MERGE) (RH-46737)
- Print: Adobe PDF crash (RH-46069)
Bug:
- 3DFace: Ngons and quads (RH-45859)
- Annotation: ON_Font::RichTextFontName() can return a name longer than 33 chars (RH-46423)
- Annotation: DimLinear: Add control of right or left text placement of text that won’t fit in linear dimensions (RH-46012)
- Annotation: Linetype: LInetype scales in Layouts (RH-46139)
- Build Process: GHA files not stored in symbol server (RH-46461)
- Decals: Cylindrical decal shows upside down. (RH-46148)
- Detail:
- Display: Locked blocks, curves and surfaces (RH-45897)
- File IO:
- 3MF tweaks for HP (RH-46226)
- Add UI (and code) to allow vertex colors to be optional in points export. (RH-46680)
- PLY files are not importing properly in V6 (RH-46652)
- Points import does not get delimiter from settings properly when it is whitespace. (RH-46704)
- VRML import broke in recent builds of V6 (RH-46610)
- Grasshopper: Preview shows on Layouts. (RH-46793)
- Grasshopper: Components: Point On Curve showing old points while disabled. (RH-46778)
- Guides: May disappear when zooming in (RH-46898)
- Gumball: Snappy/smooth setting doesn’t stick in Options dialog (RH-46755)
- Help:
- Installer:
- Menu: Add Privacy Policy to Help menu (RH-46835)
- OpenNURBS:
- Print: Rhino PDF to Larger Sheet Sizes - No Print Weight (RH-46149)
- PrintPreview: Print display line ends (RH-44688)
- RDK: Document appears to be empty (RH-46786)
- Rhino Installer Engine: V6 off-line help must be installed as “Just me” and not as “All Users” (RH-46757)
- SDK: GHPython: ghpythonlib.components do not take **kwargs properly (RH-46672)
- SDK: RhinoCommon:
- Selection: Make SubD control polygon pickable (RH-46067)
- SmartTrack: Implied from smarttrack move by distance is busted in v6 (RH-46739)
- Templates: Invalid Default Template File (RH-46780)
- ViewCaptureToClipboard: View capture from Raytraced kicks off a rerender when it shouldn’t (RH-46313)
- VolumeMoments: Typo in report (RH-46682)
Regression:
