Rhino 6 SR20 (6.20.19322) Is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation: Moved fixes for arrow, text placement and forcing dimline from v7 to v6 (RH-55119)
- Annotation: DimLinear: Dimension Text not relocating to outside (RH-55208)
- Annotation: Styles: Move FitText Down on Annotation Style (RH-55171)
- Annotation: Text: Orientation flips to mirrored (RH-53200)
- Display: FolderWatcher erroneously deletes texture map (RH-54934)
- File IO:
- Grasshopper:
- Installer: Security alert in installer of 6.21.19311.14241 (RH-55624)
- Patch: ClosestPoint gets wrong answer on Patch surface before adding it to the doc (RH-55152)
- Picture: Turns into black when changing color mask threshold (RH-54790)
- Properties: Move Arrow/Line controls to the Arrow Section (RH-55172)
- Purge: Purge messes up annotation text (RH-54887)
- SDK: Python:
- SDK: RhinoCommon: Comments that point to SweepTwoRail need to be adjusted (RH-55228)
- Settings: LoadProfile* doesn't set default if setting doesn't exist (RH-54905)
- ShrinkTrimmedSrf: Over splitting (RH-54987)
Crashes Fixed:
- File IO: [Import DWG] FillMeshHole Command: tl!Tri2dPgon – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-55304)
- OpenNURBS: ONX_Model exception reading 3dm bitmap table (RH-55383)
- RDK: rdk!CRhRdkContent::CImpl::IsOwnedByDocument – Access Denied (RH-55000)
- ShowNotifications: Double-click at blank area crashes Rhino (RH-54061)
Regressions Fixed:
- Annotation: Leader: Leader With Text Trails Lead Back to Zero (RH-55468)
- File IO: Dimensions lose style properties (RH-54936)
SDK Enhancement:
- SDK: RhinoCommon:
Tasks Completed:
- Tutorials: Update v6 user's guide model xml files (RH-53449)
Usability Problems Fixed:
- Display: Control points and polygon to the front (RH-26022)
Mac-Only Changes
Bugs Fixed:
- Annotation: DimLinear: Space Between Check Box and Label. (RH-55231)
- Dark Mode: Popup toolbar background color is incorrect (RH-54898)
- Display:
- EditPythonScript: EditPythonScript not implemented on Mac (RH-44751)
- Eto: No SelectedItemsChanged event on TreeGridView when click/drag item (RH-50396)
- File IO: Obj export on Mac doesn't save the texture name within the Mtl (RH-54986)
- Grasshopper:
- NetworkSrf: NetworkSrf and History - fails on Mac (RH-55058)
- RDK: Texture: Cannot select Bitmap (RH-55595)
- Rendering: Materials: Lock repeat icon padding has increased in texture settings (RH-55112)
- SDK: RhinoCommon: Offset component orientation inconsistent between GH for Windows and GH for Mac (RH-36841)
Crashes Fixed:
- __pthread_kill (RH-51383)
- -[MRDocumentModelWindow sendEvent:] (RH-54522)
- Close: libsystem_kernel.dylib:__pthread_kill (RH-54252)
- Grasshopper: System.NullReferenceException: Object reference not set to an instance of an object (RH-55121)
Incomplete Port:
- UndoMultiple: Implement on Mac (RH-51590)
Tasks Completed:
- Build Process: Notarize the application with Apple (RH-49086)
- Display: Use one pixel format and a single shared context (RH-55296)
Windows-Only Changes
Bugs Fixed:
- Properties: Properties jitters (RH-54869)
Regressions Fixed:
- Distance: Rhinoscript regression (RH-55449)
