Rhino 6 Service Release 10 Available
Rhino 6 SR10 (6.10.18308) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
  • Annotation:
    • Dim ObjProps - Clicking User arrow with no blocks in the file removes arrows. (RH-48700)
    • Resize the dimension editor (RH-44975)
  • Annotation: DimLinear: Can’t change Linear Dimension’s arrowhead (RH-48636)
  • Cycles:
    • Larger then viewport captures with Raytraced are blank (RH-44181)
    • Sometimes result in blank or black image (RH-45147)
  • Display:
    • Accuracy Needs to be Improved when Zoomed in Close (RH-44895)
    • Baked object shows wrong texture mapping while being dynamically transformed (RH-48738)
    • Closing options dialog makes display think AdvancedTexturePreview state has changed (RH-48251)
    • Curve display incorrect on microscopic curve (RH-44360)
    • GH drawing in block previews (RH-48603)
    • Incomplete clipping plane intersection In the Display (RH-46205)
    • Technical modes with shadows on produce a rectangle artifact (RH-42875)
  • File IO: Set default for line wrapping in obj export to off. (RH-48323)
  • Geometry Core: Add Rhino TestCorruption command that testing .NET managed breps and meshes for corruption that causes crashes in Rhino. (RH-48729)
  • Localization: German macro editor won’t open (Needs testing in SR10) (RH-48705)
  • Make2D:
  • NamedView:
    • Create view from widget ignores ortho (RH-42090)
    • Restoring multiple named views only shrinks the viewport (RH-46089)
  • OpenNURBS: Make it easier to use the C++ opennurbs pubic library in Visual Studio (RH-48727)
  • RDK: Assert triggered in RDK when about to add bitmap texture (RH-48736)
  • Rendering: Materials:
    • Layer Material dialog takes too long to appear (RH-48717)
    • Layer material issues (RH-48421)
    • Linked block materials do not update after edit (RH-44908)
    • Rendered mode materials not showing after OBJ import (RH-48761)
  • SDK: Brep.MergeCoplanarFaces out of tolerance (RH-46914)
  • SDK: GHPython: specialized tree access for GHPY compilation issues (RH-48754)
  • SDK: Python:
    • rs.ObjectsByType doesn’t use ‘state’ parameter properly (RH-44476)
    • rs.filter.morph should be 131072 (2^17) , not 13072 (RH-44902)
  • SDK: RhinoCommon:
    • Get Broken History Warning state? (RH-48311)
    • GroupTableEventArgs doesn’t provide access to the effected group (RH-48233)
    • SDK RhinoCommon FileSettings.AutoSaveFile setter no longer working? (RH-48721)
  • Scale: Default scale factor as distance units (RH-48698)
  • Sketch: Make it ignore ortho and gridsnap (RH-48709)
  • SubD: SubD to NURBS - Gaps at dart vertices (RH-31322)
  • Templates:
    • Problem with Default Annotation Style Length Unit Setting In Some Templates (RH-45791)
    • Problem with Inch Fractional Annotation Style Length Unit Setting In Some Templates (RH-45792)
  • ViewCaptureToFile: Remember resolution setting in scripted version (RH-48689)
Usability Problems Fixed:
  • Templates: Default justification for Text and TextObject incorrect (RH-44045)
Rhino 6 SR10 Hot Fix 1 (6.10.18311) is now available:
Bugs Fixed:
  • Installer: SR9 install issue - Please enter the name or IP of your Zoo server (RH-48903)
Crashes Fixed:
