Rhino 6 SR24 (6.24.20079) Is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation: Text is yellow but not selected after changing Horizontal alignment (RH-56886)
- Display:
- Export: File IO SKP: Export fails with CM units (RH-56590)
- File IO: File IO SKP: Can't export (RH-55295)
- Properties: Dead zones in Layer drop down menu (RH-56902)
- SDK: Python: SDK Python: Bug in rs.AddHatch() (RH-57120)
- SDK: RhinoCommon: SDK RhinoCommon: Mesh.Faces.RemoveZeroAreaFaces() removes all faces (RH-56867)
- Sun: Wrong timezone for Riga and Vilnius at Sun tab (RH-56802)
- Toolbar: Double RMB-click shouldn't place a text file on the desktop (RH-56996)
Enhancements:
- Match: Keep the point spacing on curve being changed (RH-56957)
Regressions Fixed:
- Print: Shaded details left out (RH-57310)
- TextObject: Font=<Name> in macro is not accepted (RH-56801)
SDK Enhancement:
- SDK: RhinoCommon: SDK RhinoCommon: Expose CRhinoGetPoint::SnapEvent() and CRhinoSnapEvent to RhinoCommon (RH-56769)
Mac-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation Text: Font issues (RH-56600)
- Display: Enable Tessellation Shaders on macOS 10.15.4 or later (RH-56985)
- Grasshopper: File > Recent Files vertical text alignment problems (RH-55339)
- Preferences: Unhide OpenGL tessellation shader checkbox (RH-57076)
Crashes Fixed:
- System.NullReferenceException: Object reference not set to an instance of an object (RH-57060)
Enhancements:
- Grasshopper: GrasshopperPluginList: Shows assembly for component in Help (RH-57015)
Features Added:
- SDK: RhinoCommon:
Performance Improvements:
- Grasshopper: Opening file takes a long time (RH-56920)
Tasks Completed:
- Display: OpenGL 3.3: OpenGL: Tessellation Shaders in macOS Catalina 10.15.4 Beta (RH-56984)
Windows-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation Text: Windows text control doesn't work right with Arial Narrow (RH-56777)
- Eto: CheckBoxCell requires 3 clicks to set check state under WPF control (RH-56708)
Crashes Fixed:
- Delete: Delete Command: RhinoCore!CCommandDelete::RunCommand – Access Denied (RH-57086)
