Rhino 6 SR26 (6.26.20147) is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Update .NET Core tooling to 3.1 (RH-57324)
- Annotation: Remove 'Cant style an empty string' message (RH-57809)
- Annotation: DimLinear: Annotation DimLinear: Macro fails with Dim command (RH-58253)
- Block: Forbids selecting Details in Block Creation (RH-58358)
- BlockEdit: Export Selected Not Working Correctly from BlockEdit (RH-57697)
- ClippingPlane:
- Display: Blocks can not display clipping plane fills (RH-45930)
- Eto: The ability to change the font of each item in a DropDown (RH-57614)
- File IO:
- Grasshopper: Components: Grasshopper Components: Mesh point inclusion test reports unexpected result (RH-57774)
- SDK: Brep.CreatePipe does not work on closed curve with kink at start/end (RH-58070)
- SDK: RhinoCommon:
Crashes Fixed:
- RhinoCore!CRhDibPrivate::DrawMasked – Access Denied (RH-58307)
- Eto: System.ArgumentException: System.ComponentModel.MaskedTextProvider…ctor (String mask, CultureInfo culture, Boolean allowPromptAsInput, Char promptChar, Char passwordChar, Boolean restrictToAscii) (RH-58304)
- File IO: Opening file crashes Rhino (RH-57563)
- Properties: com.mcneel.rhinoceros.RhCore:-[MRObjectPropertiesBasicSection runScript:] (RH-53180)
- Toolbar: System.Runtime.InteropServices.ExternalException (0x80004005): System.Drawing.Graphics.CheckErrorStatus (Int32 status)(merge) (RH-51066)
SDK Enhancement:
- SDK: Added GetGrevillePoints and SetGrevillePoints SDK functions (RH-57814)
- SDK: RhinoCommon:
- Settings: Allow users or developers to override double-click code for BlockEdit with a setting (RH-57683)
Usability Problems Fixed:
- Annotation: Dot: Annotation Dot: Properties panel issue (RH-57223)
Mac-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation Text: Properties Not Updating (RH-51248)
- Code Editor: Python: Code Editor: Python: Window goes behind (RH-57475)
- Eto: MessageBoxDefaultButton has no effect on Mac (RH-57980)
- Export: Dialog box is not visible (RH-56926)
- Localization: Rhino 6 in Russian not available (RH-58051)
- Print: SetFrustum throws ON_ERROR in print dialog (RH-57575)
- Undo: Does not work properly in sub-node controls (RH-48986)
Crashes Fixed:
- System.ArgumentNullException: Value cannot be null. (RH-57658)
- Eto: System.NullReferenceException: Object reference not set to an instance of an object (RH-58031)
- Grasshopper: System.NullReferenceException: Object reference not set to an instance of an object (RH-55121)
Tasks Completed:
- SDK: RhinoCommon: SDK: RhinoCommon: Update to Mono 6.8, Xamarin.Mac 6.14.1.39, and .NET Core SDK 3.1.200 (RH-57662)
Windows-Only Changes
Bugs Fixed:
- Core Architecture: Rhino V6 initialization stops after trying to load a V7 file (RH-57247)
- Eto: Made ButtonSegmentedItem's Enabled property look grayed out when `false' (RH-57696)
- SDK: RhinoScript: SDK RhinoScript: TextObjectText resets text style (RH-58204)
Crashes Fixed:
