Rhino 6 SR25 (6.25.20114) Is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation: DimAngular: Annotation: DimAngular: Changing the DefPoint of an angular dimension extension doesn't work if the point is on the same line as the extension in question. (RH-57279)
- Annotation: Leader:
- Annotation: Text: Annotation Text: Italics permanent (RH-53387)
- Display: Vertex colors shouldn't override Arctic display mode (RH-57467)
- Explode: Dimension text to dimension plane (RH-57519)
- File IO: SKP export: Quad faces are not exported properly (RH-57964)
- Grasshopper:
- Print:
- SDK: RhinoCommon: SDK RhinoCommon: DisplayModeDescription.RenderedId returns Guid.Empty (RH-57443)
- ScreenCaptureToFile: Screen Capture: Transparent background makes object edges transparent (RH-57035)
Crashes Fixed:
- Annotation: Leader: Annotation Leader: opennurbs!ON_TextRun::WrapTextRun – Access Denied (RH-57286)
- SDK: RhinoCommon:
Enhancements:
- Annotation: Annotations: Provides a warning when a used font is missing on the current system (RH-54667)
Features Added:
- Grasshopper:
Regressions Fixed:
- ExtractPt: Fails on sub-objects (RH-57347)
- File IO: UseCompressionWhenSaving back-ported to advanced settings to V6 (RH-57344)
SDK Enhancement:
- RDK: Expose CRhRdkDocument::ShowContentTypeBrowser() in C# sdk (RH-57349)
Usability Problems Fixed:
- Grasshopper: Sizing of Components: Hyperbolic etc. (RH-56921)
Mac-Only Changes
Bugs Fixed:
- Grasshopper: Save dialog pops up repeatedly when quitting with multiple Rhino and GH documents open (RH-57116)
- Localization: Untranslated YesInYesNoField and NoInYesNoField strings in cs, pl, pt (RH-56982)
- SelLayer: Selects the wrong layer (RH-57913)
Crashes Fixed:
- Layer: com.mcneel.rhinoceros.RhCore:-[MRDocument _layersChanged] (RH-55122)
Features Added:
- Layer: Sorting is not fully supported (RH-36493)
Windows-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation: Text: Properties font dropdown sometimes displays wrong font (RH-57335)
- SDK: RhinoScript: SDK: RhinoScript: AddLeader returns NULL (RH-57415)
- TextField: Function selection difficulty (RH-57531)
Features Added:
- Grasshopper: Alphabetise tree items in object browser. (RH-56714)
