Rhino 6 SR16 (6.16.19190) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation:
- Annotation: DimAngular: DimAngle - values over 100º are off-center (RH-52356)
- Annotation: Hatch: Hatch scaling cannot be enabled in Rhino 7 (RH-52045)
- Cycles:
- Bump map intensity can’t be adjusted in Raytraced mode (RH-52428)
- Compute tangents for render meshes prior to pushing to Cycles (RH-52111)
- Crash in Cycles BVH building (RH-52703)
- Cycles appears to ignore the transparent color when the diffuse channel is anything but black. (RH-44097)
- Glossiness and Polish has changed in Raytraced (RH-53403)
- Raytraced doesn’t honour texture amount of Rhino Custom material (RH-52812)
- Raytraced environment map on glass-/gemlike broken (RH-44078)
- Display:
- Artistic tech mode generates silhouettes too late which creates display flicker (RH-52499)
- Drag-Drop geometry in custom display mode causes “flicker” when dropped (RH-52407)
- Partial selection highlight (RH-52008)
- Selecting one object makes other objects look selected too (when shade-highlight is enabled) (RH-52527)
- Tiled drawing can cause skylight shadows to not look right (or crash!) (RH-52507)
- ViewCapture/Print with skylight shadow tile padding should be optimized (RH-42208)
- Drag and Drop: Named items move creates copy instead (RH-52600)
- Export: Export ignores 3dmbak setting (RH-52553)
- File IO:
- Join: Destroys existing ngons (RH-52761)
- Licensing: Cloud Zoo: Remove SR decimal designation from message (RH-49020)
- Localization: Spelling correction (RH-52862)
- MatchSrf: MatchSrf - Dash version in radians (RH-52366)
- No Subsystem:
- Pipe: Trims funny (RH-1220)
- Print: Tiling problem printing from Layout (RH-52493)
- Properties:
- RDK:
- Rendering:
- Rendering: Texture Mapping: Common Library Materials Not Being Found (RH-52654)
- SDK: Python:
- SDK: RhinoCommon:
- SDK: RhinoScript:
- SelPt: Fails on PointCloud > Remove (RH-52980)
- Shell: History broken warning (RH-52982)
- Snapshot:
- TextField: List of Blocks for BlockInstanceCount Shows Up Blank (RH-53470)
- Torus: Second radius constrained (RH-52329)
- Trim: Fails in layouts (RH-52281)
- ViewCaptureToFile: Setting the scale is not remembered (RH-49952)
Cosmetics:
- Layout: ImportLayout - Dialog box typo (RH-50558)
- PointDeviation: Start/End button may display offscreen (RH-52245)
Crashes Fixed:
- Eto:
- ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: Type for ‘Rhino.UI.Controls.EtoCollapsibleSectionHolder+SectionContainer’ could not be found in this platform (RH-50349)
- System.IO.FileLoadException: Retrieving the COM class factory for component with CLSID {7AB36653-1796-484B-BDFA-E74F1DB7C1DC} failed due to the following error: 8007045a A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A). (RH-50017)
- File IO: Import Command: import_STEP!ClosestPointBad – Access Denied (RH-53450)
- FilletEdge: RhinoCore!CVRBSrf::GetSectionIds – Access Denied (RH-52916)
- MeshTools Plug-in: MeshTools!FindBestEdgePair – Access Denied (RH-52582)
- OffsetMesh: RhinoCore!RhinoMeshOffset – Access Denied (RH-52611)
- SplitEdge: Crash on BREP in a block (RH-52516)
Features Added:
- Grasshopper: Components: Add a curve midpoint component (RH-52784)
Regressions Fixed:
- Annotation: Text: Grouped text, double-click editing (RH-52950)
- Display:
- File IO:
- ViewCaptureToClipboard: ViewCapture output is wrong in parallel view (RH-53656)
- WeldVertices: Only weld two vertices at once (RH-52559)
SDK Enhancements:
- RDK: RenderTexture.IsHdrCapable can not be overridden (RH-52530)
- SDK:
- SDK: RhinoCommon:
