Rhino 6 SR13 (6.13.19058) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation: DimAngular: Curve thickness set in display modes mistakenly applies to Angle dimensions (RH-50485)
- Annotation: DimLinear: History update broken (RH-50567)
- Cycles: Hide RhinoCycles commands (RH-43926)
- Eto: Eto dialogs using Python no longer work in SR13 (RH-50633)
- Insert: Angle setting uses radians instead of degree (RH-50074)
- Localization:
- No Subsystem: C++ SDK has been broken (RH-50534)
- SDK: RhinoCommon: Zoo template needs to create object that inherits from IZooPlugIn3 (RH-44458)
- SDK: RhinoScript: Rhino.RotateView direction parameter not optional (RH-50486)
- Update System: Driver check link URL gives server error (503) (RH-50644)
Cosmetics:
- Localization: Japanese: Export > Adobe Illustrator dialog > Preserve model scale needs more width (RH-50273)
- Properties: Capitalization of selected Surface in Properties panel inconsistent (RH-50419)
Crashes Fixed:
- MergeEdge: RhinoCore!AdjacentEdge – Access Denied (RH-50039)
- No Subsystem: Crash on localized versions of Rhino while rendering previews (RH-49180)
- RDKCrash: rdk!CTextureBakingAppearanceFingerprintIdentification::Identify – Access Denied (RH-50222)
- Rebuild: Crash rebuilding closed curves (RH-50639)
- SDK: RhinoCommon: Crash with preview rendering (RH-50823)
Enhancements:
- Grasshopper: Components: Grasshopper Components Update Kangaroo to v2.5.0 (RH-50768)
- SDK: Need function to split Brep with one or more Breps (RH-42917)
- UserText: Dashed Properties command should work for AttributeUserText (RH-50144)
Features Added:
- Cycles: Textured emission channel on Cycles Emissive (RH-45658)
Regression:
- Annotation: Font in drop-down changes to Arial when highlighting text using “Gill Sans MT Condensed” font (RH-50733)
- UnwrapTextures: Previous seam selection in Unwrap doesn’t work (RH-43492)
SDK Enhancement:
- Cycles:
- SDK:
- SDK: Python: Add filter description to help docs (RH-45065)
- SDK: RhinoCommon:
