ebarone
(Ebarone)
April 14, 2018, 5:36am
1
I just got rhino 6 and the picture command isn’t working.
I’ve tried JPEG and PNG files and they both just give me white planes with no image. I saw a suggestion to use -PictureFrame and the pictures path but I either did it incorrectly or it doesn’t work.
I can use an background bitmap, but I laser etch the images so unless I can remove the grid from the image it’s useless to me.
If antone knows a fix for this I’d be eternally greatful.
Thank you.
nathanletwory
(Nathan 'jesterKing' Letwory)
April 14, 2018, 10:28am
2
Can you please post the results of Help » System Information
ebarone
(Ebarone)
April 14, 2018, 4:20pm
3
Here you are
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 7 SP1 (Physical RAM: 3.5Gb)
AMD Radeon™ HD 6520G (OpenGL ver:4.1.11247 Compatibility Profile Context)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 512 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Roissy88
(John)
September 18, 2019, 2:55pm
4
Issue: Similar to @ebarone this problem persists
Thanks for any help!
System information:
Rhino 6 SR17 2019-8-23 (Rhino 6, 6.17.19235.15041, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Commercial, build 2019-08-23
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DEHER1N7287
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 12-10-2018 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 2-27-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 391.03
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-27-2018
Driver Version: 23.21.13.9103
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
C:\Users\heminjoh\Downloads\CatmullClarkSubdivision.rhp “CatmullClarkSubdivision” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.17.19235.15041
John_Brock
(John Brock)
September 18, 2019, 3:03pm
5
I would start by updating the driver for both your display adapters.
There are current drivers for both from this month.
Do not rely on the various check for updates tools, as they ALL LIE.
Go to the chip maker’s respective websites and manually find the current driver for your cards and your version of Windows.
See if that gets you sorted.
Roissy88
(John)
September 18, 2019, 3:47pm
6
Thanks @John_Brock
Drivers updated, Picture command not working.
Thanks for any other help!
System Information
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-23-2019 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 8-27-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 8-27-2019
Driver Version: 26.21.14.3186
Rhino plugins
John_Brock
(John Brock)
September 18, 2019, 3:52pm
7
Can you open this file, and do you see an image?
TestFile4Roissy88.3dm (825.4 KB)
John_Brock
(John Brock)
September 18, 2019, 3:58pm
9
Have you modified your Wireframe working display mode?
In Options > View > Display Modes > Wireframe, select the Restore Defaults button.
Does that correct the problem?
How many monitors are you running?
Are you using a docking station?
Roissy88
(John)
September 18, 2019, 4:07pm
10
Restore Defaults did not work.
Setup:
two external LG monitors, one HDMI, one USB-C
No docking station
I unplugged both and restarted your file but without success.
John_Brock
(John Brock)
September 18, 2019, 4:24pm
11
If you disconnect the USC-C monitor and start the system with only the one HDMI monitor connected, does that change anything?
Roissy88
(John)
September 18, 2019, 5:18pm
12
This doesn’t change anything either. All combinations are unsuccessful.
John_Brock
(John Brock)
September 18, 2019, 5:25pm
13
The only other thing I see is you have a plug-in loaded I’m not familiar with.
In Rhino Options > Plug-ins, disable it.
Restart Rhino without out it.
Does that make any difference?
I’m guessing not but I don’t know.
nathanletwory
September 18, 2019, 8:07pm
14
Perhaps you can try attaching a monitor to your discreet GPU (the NVidia GPU) and make sure that is set to be the primary monitor.
Right now it looks like your Intel GPU is showing all the results, but the NVidia GPU is doing the drawing part. Both drivers for Intel and NVidia look very recent, so best to try and see if ensuring only one GPU is used at a time works.
Roissy88
(John)
September 19, 2019, 7:57am
15
@John_Brock deactivating CatmullClarkSubdivision.rhp was the solution. Have tested it on other machines, plug-in seems to interfere with the picture command. I’ve contacted the developers.
Thanks both for your input on this matter! Very helpful.
