orionkeith
(Orion Keith)
August 16, 2019, 4:02pm
1
Hi there.
I couldn’t find any other posts having issues with this. In Rhino 6 I can run the Picture command and select a picture to place, but as soon as I have picked the two points, it immediately crashes. This has been true of images as small as 8kb and up to 2mb. I’ve tried jpg and png so far and both have the same effect.
Any thoughts?
AlW
August 16, 2019, 4:09pm
2
Well, so far just the usual: Run the Rhino System Info command and post the results here, attach a couple of photos that aren’t working.
orionkeith
(Orion Keith)
August 16, 2019, 4:45pm
3
Here’s the system info. Any and every image has the same result, but most recently I tried this image of Lil Wayne.
(1.7 KB)
pascal
(Pascal Golay)
August 16, 2019, 4:52pm
4
Hello- I cannot get at your system info file for some reason - can you just copy/paste into your post?
Fred_C
August 16, 2019, 4:56pm
5
@pascal found it posted here:
https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/0/1/01e2c6d1b47da60d91f07193f8dd6c78fa9f9c24.txt
Rhino 6 SR8 2018-8-28 (Rhino 6, 6.8.18240.20051, Git hash:master @ d037927543424e8b3ce54e46b435866178a6349c)
Licence type: Commercial, build 2018-08-28
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: S-FCC88M2
Quadro P2000/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.16)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-30-2017
Driver Version: 23.21.13.8816
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.8.18240.20051
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin” 2.5.19102.1302
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.8.18240.20051
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
orionkeith
(Orion Keith)
August 16, 2019, 4:59pm
6
Thanks for your help all, I appreciate you taking the time to look at this!
pascal
(Pascal Golay)
August 16, 2019, 5:13pm
7
@Fred_C - Thanks !
@orionkeith - I’d definitely update your video driver -
Open the Notifications panel (Panel menu) and look for a notification about drivers - double-click on that and follow along to get to a newer driver - download and install that and see how things work.
And I’d also look at blocking Vray in Options> Plug-ins page (uncheck ‘Enabled’) and then restarting Rhino and see how that works.
Willem
(Willem Derks)
August 17, 2019, 8:02am
8
In addition @orionkeith , you should update Rhino as well. You are about a year behind.
-Willem
orionkeith
(Orion Keith)
August 19, 2019, 6:26pm
9
Thanks @pascal & @Willem , After having IT update our Rhino 6 deployment and updating to the most current release, Picture works without issues.
