aversis
(Info)
April 19, 2019, 7:36am
1
I think since the latest update (SR13 - 6.13.19058.371), I get strange behavior when using ghosted viewport. If an object is selected, and I pan/zoom in the viewport, there appears a strange ‘ghosting’ effect. When no objects are selected there is no problem when panning/zooming. when the ghosting is present, and I simply deselect the object, the ghosting traces go away.
I have this behaviour on my laptop and desktop computer (both windows 10).
Any ideas? Is there a way to step back to the previous rhino release?
Thanks,
Wouter
Can you type _SystemInfo at the command line on either/both of your machines and post the results here?
aversis
(Info)
April 19, 2019, 8:14am
3
Hi, here you go:
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Commercial, build 2019-02-27
License details: Cloud Zoo. In use by: Wouter Wynen ()
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: AVERSIS-PC-2017
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1080 (NVidia) Memory: 8GB, Driver date: 1-11-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 417.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-11-2019
Driver Version: 25.21.14.1771
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
pascal
(Pascal Golay)
April 19, 2019, 3:07pm
4
Hi Wouter - this bug showed up, for some users at least, in 6.10 and/or 6.11 and seems to have been fixed in later versions - apparently that is not the case for you. I’ll investigate…
I see it here in 6.13, 6.14.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49052
