I assume this comes from intersecting surfaces, is there a way to keep the transparency settings but do not have everything flickering?
Thank you
Hi Hannes,
Can you run the systeminfo command in the Rhino command line and post the results here? Thanks.
@Japhy sure!
Thanks for helping me
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Commercial, build 2023-02-27
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 3-16-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.41
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-16-2023
Driver Version: 31.0.15.3141
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Users\hanne\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot12RhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.1.0.0\KeyShot2023RhinoPlugin\Rhino 7\KeyShot2023RhinoPlugin.rhp âKeyShot12RhinoPluginâ 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp âWebBrowserâ
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp âRPCâ
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp âRhino Labs Toolsâ
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp âAnimationToolsâ
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp âIdleProcessorâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp âLegacy Rhino Renderâ
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp âAlerterâ
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp âCalcâ
please go to you File>Properties>Plugins and disable the Keyshot and restart Rhino
Properties > Plug-ins you can locate it, right click and choose Properties - there you will be able to see the location of the rhp (plug-in) file. You can remove it from there as one way to uninstall (if not via package manager or accompanied by an uninstaller)
@japhy did not help. But thank you. Good to know. Can you estimate what the problem could be?
These are default display modes?
is it only in a particular file?
not necessarily default, but maybe defaults even if edited.
my reference was per a particular instance where one mode may be calculating render mesh and upon failure or time-out, Rhino will switch to X-ray mode to bypass render mesh calculation â I think.
Yup, there is the command ClearAllMeshes that wipes and puts the user in wireframe.
If its a particular file the first thing to check is SelBadObjects.
Deactivated Plugin issues are the same x-ray
X-ray is not related to file but everywhere. Itâs in a viewport view with custom settings, a similar view with only shadows turned off does not have the issue.
Flickering in custom ghosted view is solved as I changed the transparency and color values for locked objects.
I believe it is a custom viewport settings which will be corrupt, as they are only settings I donât understand why this custom view that generates these x-ray issues will be corrupted at all.
But I simply will copy the similar version and set it as another custom viewport (with shadows) to have the state and all its previous settings back.
Thank you
Worked for me.
What worked?
@lander Copied and renamed a slightly different but working display style and switched on one or two parameters (turned on shadows etc).
Everything works like a charm again.
Thatâs one of my favorite things to do to the âRenderedâ display mode ![]()
It unlocks the shade object setting and rendering material, and has alot of settings I like that other modes donât have.
@lander tested the viewport settings files from @Rhino_Bulgaria and they are way better.
