This problem seems to arise when installing the update to Rhino 6. If I uninstall and reinstall Rhino 6 and select to not update, it seems to fix the display problem.
The wireframe and raytraced display modes are the only ones that seem to be unaffected. Shaded and ghosted views show whatever surface geometry to be extremely skewed and scaled up. The shapes also don’t move when moving around the viewport, but the shading seems to change dynamically when moving around.
Here are some images of what I mean, and the OpenGL information:
NVIDIA Corporation
GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2
OpenGL version: 4.6.0 NVIDIA 389.34
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-17-2018
Driver Version: 23.21.13.8934
Z-Buffer depth: 24bits
Stencil depth: 8bits
Total Video Memory: 4 GB
Thanks,
Ryan
nathanletwory
(Nathan 'jesterKing' Letwory)
February 5, 2019, 10:02pm
2
Does it work any better if you disable (load-protect) the V-Ray plug-in, then restart Rhino?
I’m not sure exactly what you mean, but disabling Vray and restarting Rhino doesn’t change anything.
pascal
(Pascal Golay)
February 6, 2019, 4:49am
4
Hi Ryan - can you please run SystemInfo in Rhino and post the results?
dorler
February 6, 2019, 6:14pm
5
Also having a similar issue.
Seems to occur when I copy from one file to another file. Started happening last month. GPU Tessellation is unchecked in OpenGL settings. My IT can’t seem to determine what’s going on. Here is my SystemInfo:
Rhino 6 SR10 2018-10-2 (Rhino 6, 6.10.18275.12371, Git hash:master @ 63dde29ec4795329e20dcbcac5a6aec0358fc638)
Licence type: Commercial, build 2018-10-02
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: SFCOLOVDIHB0099
Quadro FX GRID M10-2Q/PCI/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.03)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Driver Date: 2-27-2018
Driver Version: 23.21.13.9103
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.6.73.0
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.10.18275.12371
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.5.0
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\Rhino.Log.rhp “Rhino.Log” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.10.18275.12371
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.10.18275.12371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.10.18275.12371
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
pascal
(Pascal Golay)
February 6, 2019, 6:18pm
6
Hello - are the objects far from the world origin?
dorler
February 6, 2019, 6:19pm
7
Yes, they’re aligned with our Civil Engineer’s drawings. We’ve relocated our cplane origin to that location for coordination efforts. We’ve been working in this manner with out issue for over two years, in Rhino 5 and 6.
pascal
(Pascal Golay)
February 6, 2019, 6:22pm
8
Hello - see if changing the check box on Options > View > openGL page > ‘GPU Tessellation’ does anything.
dorler
February 6, 2019, 6:28pm
9
Unfortunately, it does not seem to have any positive effect. Checking the box makes it worse/same, leaving it unchecked has similar results.
-Also, thank you for the quick responses!
pascal
(Pascal Golay)
February 6, 2019, 6:30pm
10
Hello - I see you are on SR10 - I’d at least try the most current SR, which is 12 -
https://www.rhino3d.com/download/rhino-for-windows/6/latest
dorler
February 6, 2019, 6:31pm
11
Let me forward this information to my IT Dept. and get them to install! I’ll check back in once we give this a go!
System Info:
Rhino 6 SR12 2019-1-29 (Rhino 6, 6.12.19029.6381, Git hash:master @ ae9d7fba5fda0b43002dc44a34e059a9a382db04)
License type: Educational, build 2019-01-29
License details: Cloud Zoo. In use by: ryankai.cheng ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-4LV7T6O
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-9-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti with Max-Q Design (NVidia) Memory: 4GB, Driver date: 5-17-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 389.34
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\RhinoCAM 2018 for R6\RhinoArt1FileExporter For Rhino6.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.12.19029.6381
I’ve posted my SystemInfo above
pascal
(Pascal Golay)
February 6, 2019, 6:45pm
14
Hello - all I can think of off hand is to force the machine to always use the Nvidia card - that’s a ‘high performance’ setting, I believe, in the NVidia control panel.
Hi Pascal, the default graphics processor to run Rhino is already High Performance NVidea processor.
pascal
(Pascal Golay)
February 6, 2019, 8:58pm
16
Hi Ryan - just as a test, can you try setting that ‘high-performance’ for the machine as a whole, assuming that is possible?
Hi Pascal, I’ve managed to fix my issue! I just updated my NVidia graphics driver and it solved it.
Thank you for your help!
