steve11
(Steve)
August 27, 2019, 11:39am
1
Good afternoon,
I have a small issue with Rhino 6 which i am running at our office.
I have 2 computers sharing 1 licence.
On one computer everything works as it should.
On the other computer the visual representation of the work is unreadable.
As a test i tried opening a new session in rhino. I then draw a simple line detail. When drawing the line i can see the line but a soon as the click off the line it no longer on the screen.
When i drag a selection box over the line it is then visible again.
If anyone has come across this or has any ideas i would welcome some suggestions.
I am guessing some sort of display setting.
Many thanks
wim
(Wim Dekeyser)
August 27, 2019, 11:43am
2
Hi Steve - please run the Rhino SystemInfo command and post the result here.
steve11
(Steve)
August 27, 2019, 11:52am
3
Hi, please see below, thanks.
Rhino 6 SR16 2019-7-9 (Rhino 6, 6.16.19190.07001, Git hash:master @ a8b4ee102e9e0eb1d11825df063e13f96d518f93)
License type: Commercial, build 2019-07-09
License details: Cloud Zoo. In use by: steve ()
Windows 7 SP1 (Physical RAM: 7.9Gb)
Machine name: STEVE-02
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 530 (Intel) Memory: 1GB, Driver date: 10-1-2015 (M-D-Y). OpenGL Ver: 4.4.0 - Build 20.19.15.4300
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.4
Shading Language: 4.40 - Build 20.19.15.4300
Driver Date: 10-1-2015
Driver Version: 20.19.15.4300
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.16.19190.7001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.16.19190.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.16.19190.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.16.19190.7001
AlW
August 27, 2019, 12:44pm
4
Your Intel driver is seriously out of date. I’m not sure the Intel 530 even has the hardware capability to run the OpenGL level that Rhino 6 requires: you will need to wait for @pascal or someone else to wake up in Seattle. Or maybe @Helvetosaur will know.
Just to satisfy your curiosity, you might want to run SystemInfo on your other machine to compare.
Rhino 6 likes up to date video drivers, and “update your video drivers” is a frequent refrain on this forum. However if you have an Intel graphics adapter which was originally furnished with a “customized” driver it may appear impossible to update the driver with the latest from the Intel website.
I have found a method to get around the blocking of the driver update and manually install the driver update. The key is to use Device Manager to uninstall the adapter after checking the box to delete…
Hello i recently installed the Rhino 6 version and it crashes in 5 minutes of me opening it.
I tried unintalling and reinstalling the software but in vain.
I read in some posts and updated the drivers too but still no luck!
However it runs in Rhino safe mode but with only wireframe as Display setting available.
Please advice as to what should i do?
Here is a systeminfo from Rhino
steve11
(Steve)
August 27, 2019, 12:55pm
5
Hi AIW,
Thank you for the top tip. I will try updating my driver and report back.
Your are correct that the computer that works is much newer.
Thank you.
wim
(Wim Dekeyser)
August 27, 2019, 2:33pm
6
Hi - It looks like those are the most recent ones for Windows 7 though. There are more recent (less than a month old) drivers for that card for Windows 10…
https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530
Does disabling GPU Tessellation in Options > View > OpenGL do any good?
