I just installed rhino 6 and the different display modes don’t work. When I select Rendered the model dissapears, Ghosted stays the same as Wired…
What can I do to fix it?
Thank you very much
Thank you very much
It sounds like you need to update your GPU drivers.
Run the Rhino SystemInfo command and paste the results here.
Rhino 6 SR1 2018-2-6 (Rhino 6, 6.1.18037.13441, Git hash:master @ 5a33e6871b94d32ba552468218cef0ad8d3d1263)
Windows 7 SP1 (Physical RAM: 7.9Gb)
Intel® HD Graphics 4000 (OpenGL ver:3.3.0 - Build 8.15.10.2712)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 3.3
Shading Language: 3.30 - Intel Build 8.15.10.2712
Driver Date: 3-26-2012
Driver Version: 8.15.10.2712
Maximum Texture size: 8192 x 8192
Z-Buffer depth: 24 bits
Maximum Viewport size: 8192 x 8192
Total Video Memory: 2112 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
You should at least update your drivers, they are almost six years old. You should be able to get your updated drivers here: Support for Intel® Graphics
This should improve your experience. Note though that the Intel HD Graphics 4000 is quite old already. According some information I found (List of Intel graphics processing units - Wikipedia) your card supports up to OpenGL 4.0. I am not sure if that is high enough for full viewport support. @jeff or @stevebaer can probably tell you better what kind of performance you should expect with your card.
