Rhino 3dm file version converter
This utility makes use of Rhino3dm.NET, which is licensed under the MIT license. Therefore no Rhino installation is required and 3dm files from Rhino 2-8 are supported.
DO NOT SAVE FILE IN THE SAME LOCATION.
Rh3dmConverter.zip (7.5 MB)
Opening Rhino 7 files in Rhino 6
Rhino 6 reading Rhino 7 Files
Rhinoceros : Open any Rhinoceros file and change It's version without having Rhino. Free rhino file converter
Convertir archivos 3dm de Rhino 7 a Rhino 6
Filling the gaps between surfaces
Trying to open Rhino v8 file in Rhino v7
Converting Rhino 7 file to 6
How to use files created in higher versions in lower versions
Rhino 8 to Rhino 7 conversion
Backwards compatibility v6, v7, v8
Wavey Unrolled Surface
Unroll & FlowAlong Surface Deformation
Can't Open Rhino 7 File Created with Rhino 8 WIP
Making a stone wall
File can not open in rhino6 by rhino7
How to make a closed terrace terrain from contour curves
Scanning with a selfie stick - need for some Bluetooth or vocal commands!
Cant access the files I made in Rhino 8 after my trial expired
Compatibility issues with Rh8 GH scripts in Rh6
Can you use Rhino 6 with Rhino 7 licence?
Modeling strategy
iRhino3D Appstore Update
Rhino 9 Feature : Multi-sided surface patches
How to design a Jighead (pyramid with bent edges)
Fast and easy way to delete fillets to cornered
Surface Pros: Help With Patch Layout?
Modeling Strategy
Rhinoscript to convert files
Sweep 2 rail failure
Map a texture along curve
Wind is not working
Rhino WIP file is corrupted after updating WIP
Convert Rhino 7 Files to Rhino 6 At Once
Rhino WIP Feature: Patch re-implemented
Trim to create panels
Awesome!
One Warning - From my testing.
Do not attempt to convert files “in place”.
Meaning this converter will not overwrite the original file after conversion.
You have to use another directory or another file name.
In fact, if you attempt to convert a file “in place”, you will delete the old file.
will fix.
Nice job, works perfectly so far. Thank you.
popping in to say this works wonderfully, saved me from keep having to chase down folks to ask them to send me a different file version
A must -have software, thanks for sharing , Andrea
You’re a genius, thank you!
How safe is it to use this software?
Perfectly safe.
Save as - and use a different filename.
Your original file remains untouched, and you get a new file.
Doesn’t get any safer.
this converter would be super useful for me. Unfortunately when I hit the browse button to find a file to convert I receive the following error message:
any ideas?
Many thanks,
John.
Download Rhino3dmIO.dll and place it in the same folder as the executable. @john11
Wonderful, thanks Farouk!
Glad I could help.
-Farouk
Does this work on Mac?
hi i accidentaly overwrite the file in same place and the files deleted itself and not even in the recycle is there a way i can recover the files
Hi Patrick,
Look for a .bak or .3dmbak file in your directory, with the same filename.
Simply replace the 3dmbak extension with .3dm and you should have your previous version back.
Otherwise, look to your backup, or to your email, if the file went through your email system.
Sending files to yourself is a quick way to provide a failsafe redundancy.
Thanks @gankeyu. This utility is very helpful because of the dialog.
There is a second utility available on Food4Rhino called Convert3DM.
It has been update for Rhino 8, and runs on Windows or Mac.
However, Convert3DM is only for those that are comfortable using Windows and Mac terminal.
If you are not then @gankeyu utility available above is best for you.
Sincerely,
Mary Ann Fugier
Saved my bacon. trialled Rhino 8 and built a model in there and it expired. couldn’t open in 6. then I found this. thank you!
Worked perfectly. Thank you very much!
