For some strange reason my RH8 stopped getting updates and thus I got a warning of expiration. As I could not figure out how to solve this issue, I decided to delete and reinstall RH8. Now it won’t even load anymore, it seems to be stuck at the startup window:
Maybe there is an issue with my license - is it possible to log out of Rhino, other than the Logout command, which is obviously not accessible to me now?
Normally, we have tests in place to catch this issue, but we’re doing some infrastructural maintenance that is impacting automated testing for V8 WIPs only.
I just attempted to reproduce this on my computer and I can’t. But I am testing with a more recent build. Can you please try with this build?
Better?
PS: It almost looks like there’s a dialog stuck in the background. Did you already try pressing control+up-arrow to see if it’s hidden back there?
as I lost all my preferences, I imported the RH7 .plist back in with ImportPreferences again. Rhino then crashed after selecting All for import. After starting it up again, it is now again in the Initializing... loop - only in German now haha
here is the .plist file that I exported from RH7: RH7.plist (442.6 KB)
Thanks for the plist. I tried reproducing this but I was unable to. Here are my steps…
Downloaded your RH7.plist preferences.
In Terminal, I ran defaults delete com.mcneel.rhinoceros.8 to reset Preferences to factory defaults
Launched RhinoWIP for V8, started a new modeling window, and ran ImportPreferences and selected your RH7.plist.
On the Import Preferences dialog, pressed the Select All button, and clicked Import. Rhino did not crash. (If I’m reading your report correctly, at this point it crashed for you.)
Quit Rhino.
Restarted Rhino.
It ran as expected…and I can see your customizations from your Preferences.
I tried the above steps while running in Deutsch, but it still worked. Sounds like you’ve got a very reproducible case on your end. Let’s figure out what we’re doing differently.
Unfortunately, I still cannot reproduce this on my machine. I did notice that I’m on a different version of macOS than you reported (are you still on 11.3.1?) I’m going to update to 11.4 soon and test again.
