Various stuff I (and others) have reported that are still happening, and I’ve lost track of the initial threads where they occurred. The menu stuff is “old” (i.e. were some of my first reported issues with V8) and have had no replies or McKneel comments since, thus this post.
The container stuff may overlap other issues but is how they tend to manifest for me.
All this stuff present as of:
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15002, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Cloud Zoo
Apple macOS Version 12.6.1 (Build 21G217) (Physical RAM: 96Gb)
Mac Model Identifier: MacPro5,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon RX 580 (8 GB)
LG HDR 4K - Left (3840 x 2159 @ 60.00Hz)
LG HDR 4K - Left (3840 x 2160 @ 30.00Hz)
LG HDR 4K - RIght (3584 x 2016 @ 60.00Hz)
USB devices
Generic: USB2.1 Hub
Tripp Lite : TRIPP LITE UPS
Generic: USB2.1 Hub
Generic: USB3.2 Hub
ASMT: USB 3.0 Destop HD EP0 Product string
Generic: USB3.0 Card Reader
Generic: USB3.2 Hub
Kensington: Kensington Slimblade Trackball
3Dconnexion: SpaceMouse Enterprise
Apple, Inc: Apple Keyboard
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
as.vit9696.Lilu (1.6.2) 264B15BE-8923-3A33-A9F5-8F0FFBB80595
as.vit9696.WhateverGreen (1.6.3) 9599C0FC-6144-3136-854C-C15FFF63706F
com.khronokernel.FeatureUnlock (1.1.2) 46C7C044-AE43-378A-8E50-F24BA68705DA
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/marklewno/Library/Application Support/McNeel/Rhinoceros/packages/8.0/FilterSelection/1.0.2.0/RhSelectionFilter.rhp “FilterSelection” 0.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15002
Menu Stuff
1 - Vanishing Menus (might be Mac only)
Menus still broken, as any defined menus vanish on quit.
While they are still define (somewhere), on relaunch they vanish until you invoke menus, add a menu (can be anything) close the dialog. When You do your previously defined menus will show back up (along with the one you just created). These will work for the remainder of the session or until Rhino Crashes, whichever comes first.
2 - Duplicated menus:
This one is erratic and hard to reproduce:
But occasionally menu names get duplicated in the menu bar (in this case “Align”)
when you check the menu editor only one exists:
General Container Stuff:
3 - Vanishing Defined Container When Locked and Docked:
I’ve got several containers defined that do NOT use any of the pre-existing container names:
This are docked in specific locations and locked.
Occasionally, and for no reasons I can reproduce (probably because I don’t see it when it’s happening, only after so thus don’t know exactly what causes it, one of more of them will “vanish”, I.E. become unchecked as far as containers is concerned, in this case “Mark’s Common Tools” from the previous screen cap.
That particular container evolves during use as it’s toolbar stuff I tend to find my self using a lot “currently” and stuff gets added and removed from this as needed based on current project workflow.
4 - Locked and Docked containers becoming NON Docked, Floating and Unusable
This one is recent (like maybe the last update). Might be Mac only.
Tends to happen mostly if I have multiple documents open on switching between the, but several of my above listed containers will undock, go floating, and outside of being able to close them are utterly non intractable. You can’t use the tools or panels in them, you can’t move them, you can’t redock them, and nothing fixes this (even a re-invocation of a previously saved Window Layout).
The ONLY way I’ve found get rid of them is to bring up the containers dialog and uncheck and recheck the container in question a couple of times to get it to “re-docK” and then repeat that process for all the rest of the “ghost orphaned floating containers”.
This one is super annoying and chews up a LOT of time. Very distracting. This also appears to have just happened recently like in the last couple of updates.
