The ground plane material no longer wants to scale properly , altho in R-5 it worked perfectly , and the bump map scaling no longer matches the applied material image . It COULD be a scaling problem , but in R-5 I had it set about medium with good results and its about same here .
As you can see , the legs SEEM to work correctly .
Any suggestions ?
Thanks !
