Hello guys,
I recently encounted a problem that the parametric display in rhino viewport got messed-up.
here is the picture shows the problem.
any ideas?
Best,
Lei
Do you have bump preview on?
Hi Michael,
Thanks for the reply.
but what is âbump previewâ you mentioned?
Found the âbump previewâ. clicked off and on but the viewport remains messed-up
Is this perhaps far from the origin? And Rhino 5 or 6?
hi wim,
I had rhino5&6 both installed.
wil that be the issue?
I just uninstalled rhino6, didn`t work.
If anything, it should work better in RH6.
Can you post the internalized results from your definition in a reduced gh file?
Yes. This is a typical point in the model. {3.8383e+7, 3.8443e+6, 33.3}
I donât follow the logic of subtracting one point from another and treating the result as a vector (or I wouldnât do it that way), but the model basically looks OK in R6. Except for âRenderedâ, âArcticâ and âRaytracedâ modes which all show blank screens. ![]()
Thanks Oster and Wim,
It`s the problem far from origin point.
Thank you all for the help!
Best
Lei
This is because now the custom preview component has a material input instead of a shader input. You set materials there and they will actually render as those materials as a gh preview when on those display modes.
Note that these materials can be document materials as well.
COOLďź this is nice.
Putting a name of material as input works. But the shininess still doesnât work for me. Am I the.only one using this ?
Thanks Michael. I just donât understand the lack of concern at McNeel for compatibility (and usability!). One of the greatest features of R6 is the dazzling âRenderedâ mode but all my old GH models are useless in this mode unless I painstakingly replace all the Custom Preview color inputs with materials - even contours!? Not only is that inconvenient, it makes the modified files incompatible with R5? Thatâs really uncalled for and rather rude. Why canât color values in old GH models be treated as the old âdefault materialâ? The geeky justifications from McNeel for making life difficult for users is quickly wearing thin.
I donât understand this? Please clarify? In R5, Iâve used Custom Preview the only way I know how. I get the same result with my own models as I did with @Lei_Yang1âs model in this thread. No GH preview geometry visible in those three rendering modes.
As @Michael_Pryor said, if you donât have Custom Preview in your old file, then you have to add it inevitably to see it in R6 Render mode.
But if the old files had a Custom Preview with shader input from the first place, you donât have to replace it to the material input.
That doesnât quite match my experience @HS_Kim. My old GH files do have Custom Preview components. Ghosted preview looks like this:
Rendered preview looks like this - missing curves, contours and curvature graphs (and what happened to the blue window frames?). Enable/Disable Preview on Custom Preview components has no effect, the components themselves must be disabled. No matter what the technical reasons are for this behavior, it is a disruption of prior practice - an unpleasant surprise,
By the way, while these images donât show it, I have a Rhino model that contains additional geometry (hulls, interior accommodation details) that look great in Rendered mode but I canât show my full GH model with those Rhino parts rendered.
