Revit levels to Rhino
I will like to get the Revit levels into rhino as lines or points or whatever geometry that I can snap to it. Is there any workflow?
Thank you in advance
Levels output as a point in space. In this definition i made a rectangle and assigned layers, colors etc using elefront.
Looks nice thank you i’ll give it a try
Can you share the definition in GH format?
sure, that definition was made for running on the player so i removed the x+1 component (from a plugin you may not have)
requires elefront only
WIP_GET_REVIT_LEVEL_FROM_ELEV_VIEW.gh (14.7 KB)
same thing works well for grids too,except from a plan view.
Thank you so much I did exactly what I was expecting
