Hi Guys,
Is there a way to bake a curve coming from the Revit level to Rhino model?
This will be nice if it updates as well coming from Revit.
Thanks
Hi Guys,
Thanks
You can use the “Element View Geometry” to get the level’ curves from the specified view and bake them, don’t believe you can update them once you bake them though
You can do the same thing we did for the grids, get to a proper view and then cast or create geometry, in this case to a plane where we make a Plane Surface.
GET_REVIT_LEVELS_FROM_ELEV_VIEW.gh (14.2 KB)
Thank you guys in responding back to my query, l believe it is working well! Kind regards.
Hi Japhy,
One thing I noticed on my Rhino screen is that the levels falls on same plane not having an elevation? thanks.
What view are you in? That seems a likely result out of a plan view.
Just wondering, but isn’t level one in this image set at elevation 0.00 ?
or does this happen with all the levels not just level one?
Hi Mohamed,
In Revit my level start at 0,0 but somehow in comes to Rhino the level planes are piled in one plane which 0.
Cheers.
What are your Rhino units? Can you post a screenshot of your GH definition?
It is now working guys, thank you very much! I open it in 2022 version as I need to see the grid action in 3d view, cool stuff having revit screen reflected in rhino screen.
