is there a way to set up levels for a projects (without GH) like in Revit ?
Kind regards,
Constantin
Kind regards,
Constantin
Hi Constantin, Revit Levels are essentially a plane. In Rhino you can save a NamedView which preserves the plane as well. You can then place objects per that floor with Visibility controlled by layer in viewports.
Another strategy would be similar to Autocad workflows where separate files for each floor are generated and stacked in a master file.
