Resolution / scale / proportions in GH canvas
I have problem with resolution or scale or proportions in GH canvas.
Some of components elongated, such as Telepathy sender/receiver or value list. Also + sign for Insert Parameter start appearing from too far, from zoomed out view.
Could anyone educate me on this one?
Hi - Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
thanks for getting back, please see below.
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Evaluation, build 2022-02-08
License details: Cloud Zoo
Expires on: 2022-05-31
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-14-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1003
Secondary graphics devices.
NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-20-2021 (M-D-Y).
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
An integrated accelerated graphics device exists and is attached to a monitor, but it’s not being used by Rhino.
  • Recommended: Use Windows’ Display Settings to configure one of the other monitors to be the “Main Display”.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.101.1003
Driver Date: 10-14-2021
Driver Version: 30.0.101.1003
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\aruzdyak\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\2.2.2.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.2.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.15.22039.13001
Artem, Please see these instructions for getting the OpenGL onto your Nvidia RTX card.
very much appreciated!!!
