Reproduceable crash behavior
1. Basic About Information
[Window Title]
Rhino.Inside - About
[Main Instruction]
Rhino.Inside© for Revit
[Content]
Rhino.Inside Revit: 1.22.8913.17329 (2024-05-27T09:37:38)
[Expanded Information]
Rhino: 7.37.24107.15001 (Rhino 7)
Revit: 2024.2 (24.2.0.63)
CLR: 4.0.30319.42000 (4.8.9241.0)
OS: Microsoft Windows NT 10.0.19045.0
[^] Hide details [Web site] [Read license] [See source code] [OK]
[Footer]
Press CTRL+C to copy this information to Clipboard
2. Isolating the issue and posting files
Files:
Repeatable Crash_RH7.gh (2.1 KB)
Revit File Download: Transfer - Dropbox
  1. Open the Revit file in Revit 2024.2. Then opens the [3D] view
  2. Open RiR in another screen
  3. Open Grasshopper
  4. Make this simple script from scratch. If you use the attached GH file Revit won’t crash.
  5. Press “Geometry Cache” to send Revit walls into Rhino
  6. Zoom extrend Rhino viewport to ensure the walls are visible
  7. In Revit create “Wall Material Takeoff” schedule. Try selecting a few rows to interact with the model
  8. In Revit now switching to the [3D] view from the material takeoff schedule.
  9. You should see this error:
I do not believe there is a license issue with my Revit.
Version of RiR tested that have the same crash behavour:
v1.21 (Hotfix)
v1.22 RC2
v1.22 RC1
Version of RiR tested without this issue:
v1.20.8836.21283
Thanks.
Thanks for the detailed crash report, i was able to repeat, albeit without the licensing dialog error.
Hello Japhy,
Just letting you know I have installed RhinoInside.Revit_1.22.8962.17228
This behaviour still exists and is not fixed yet, from my experience.
This is getting attention, the devs had me send your example file the other day (dropbox link expired), unfortunately no fix to test as of yet, hopefully soon.
Please test the latest daily build (or above) 1.24.8993.20598
Hi Japhy,
Sorry for the delayed response - finally got time to test the latest build.
I think this bug has been resolved.
Using 1.24.9022 + Rhino 8 SR11
No crash so far.
Thank you
