Revit Keeps Crashing
Anyone else experiencing revit fatal crashes using rhino inisde?
I have been using RIR for the past 2 months with limited issues. I recently updated to the newest version and now Revit will crash after having RIR open for a short time. Not loading large scripts or doing anything I hadnt been doing before.
I also tried reloading the older version and still happens.
Hi Will,
Lets look at your info. Please go to your Rhino.Inside.Revit about and see details.
This could be related to a Revit Addin. A quick way to troubleshoot is to isolate Rhino & Revit from other revit addons we can start a new instance of Revit like so…
Hold Shift+Cntl and the Rhino Start Button on the Revit Ribbon (Green Dot)
Iam having the same trouble. First i tried What Japhy told me and troubleshoot to see if it was an addon or plugin problem. But even after a restore the pc and install just revit qnd rhino the problem persistsz
I believe the error to be rhino. I am able to use Grasshopper inside revit no problem. But as soon as I open rhino I have about 5 minutes to work before a fatal error.
The only other addon I have is enscape.
I did what you asked but am unsure how to get informatino useful for you
Enscape in Rhino as well as Revit? Please disable the Revit addin for testing purposes.
Does this only happen in files with enscape materials/material panel open? There is a RDK issue we are fixing that could be related.
What is your Rhino systeminfo? (run SystemInfo in the Rhino command line). Thanks
I have not been using enscape and only ever edit materials using the revit material editor.
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Evaluation, build 2024-07-12
License details: Stand-Alone
Expires on: 2024-08-11
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9256.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 16GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24194.18121
Please disable via File>Properties>Plugins and restart Rhino. Thanks
I removed enscape from my computer. Revit still encounters a fatal error with rhino inside open. Grasshopper inside still works without issue.
It even happens when I have one view open in revit and a blank rhino document
That is unusual.
What version of Revit are you in?
Nvm. It just crashed with only grasshopper open. Albeit it lasted longer…
Revit 2024
I am Uninstalling and Reinstalling both revit and rhino.
I will let you know if this solves the issue
Here’s new troubleshooting method we are trying.
RevitUtilityScripts_R24.rvt (436 KB)
First you’ll need to enable macros in the document and then restart.
Then run this macro that will collect all the .dlls being loaded into the file.
Then Cntl+A the dialog, then Cntl+C
Put the results into a hide details widget or send to me privately.
I have reloaded the apps. I reverted back to this version “RhinoInside.Revit_1.20.8836.21283”
So far it is running smoothly.
I wont have time to test the new version again for a bit.
Hello! How do I revert to that version also?
