Revit Crashing when RiR Opens or Shortly Thereafter
If I initiate RiR and then open grasshopper, Revit crashes. If I open Rhino first and then grasshopper it works for awhile, and then freezes, then crashes.
RIR:
Rhino.Inside Revit: 1.25.9063.15948 (2024-10-24T08:51:36)
Rhino: 8.13.24317.13001 (Rhino 8)
Revit: 2024.3 (24.3.0.13)
CLR: 4.0.30319.42000 (4.8.9282.0)
OS: Microsoft Windows NT 10.0.22631.0
System info:
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9282.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 11-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.17
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-9-2023
Driver Version: 31.0.15.4617
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.1.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.220\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.220.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.51.2\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.51.2.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
Revit Ribbon + Add Ins:
Hi Matt,
It looks like you are running 4.8 in Rhino 8. Did you set this or one of the plugins?
To troubleshoot we need to isolate from the Revit Addins and potentially the Rhino/Grasshopper as well.
To start a new instance of Revit with no other addins…
You can disable Rhino addins via File>Properties>Plugins sort by plugins that do not ship with Rhino.
Moving the Grasshopper plugins to a new folder outside the path temporarily is a quick method, or you can load via Rhino command line with GrasshopperLoadOneByOne and say no to 3rd party GH plugins.
Ah yes, I rolled it back so the hide wires shortcuts work in grasshopper:
I will try reverting to default to see if that works.
Thanks Japhy
That seems to have done the trick.
Thanks Again
