I am having repeated crashes on a file.
It simply goes into ‘thinking’ with a spinning blue donut, which still moves when the mouse is moved. After a while the donut freezes, it is not possible to switch to my other app. And i need to force a shut down. No crash report is created, no crash backup is created.
Last crash I was simply zooming.
Technically, these are not crashes. Rhino is still running but clearly not finishing the operation.
Try running the SelBadObjects command.
Fix or replace any bad objects and see if that gets you sorted. https://wiki.mcneel.com/rhino/badobjects
Any luck?
This could also be a plug-in problem.
Please run the Rhino SystemInfo command and return those results in a reply.
Thank you John,
No Bad Objects were selected.
Rhino is operating while the blue donut is spinning, I guess. But I can’t do anything with the computer, I can’t switch to another app. After a while, the donut stops and even if I wait long I cannot do anything with the computer.
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Intel(R) Iris(R) Graphics 540 (Intel) Memory: 1GB, Driver date: 10-11-2018 (M-D-Y). OpenGL Ver: 4.5.0 - Build 24.20.100.6299
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.5
Shading Language: 4.50 - Build 24.20.100.6299
Driver Date: 10-11-2018
Driver Version: 24.20.100.6299
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\NunoAlmeida\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.5.1\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
Yes, I know it is not ideal , but I have run much larger files in Rhino 7 here already. It is not fast but I am slow myself and it held its own, rarely crashing/hanging.
Not sure what is going on. I started a file from scratch, and it has not happened yet and is well due a crash by the last couple of days standards. I have a colleague working with the (crashing) file on another computer with no problem.
I’ll try update the driver in any case, Thanks, N
Wim is right.
That computer with only an Intel GPU is a potato.
It doesn’t meet Rhino’s minimum system requirements.
An updated driver is the first place to start.
You have to manually get it yourself:
If it still locks up or crashes, then short of buying a supported system, you can dial back the OpenGL requirements but you’ll lose some display abilities in the process.
After you update the driver, and if you continue to have problems:
In Options > View > OpenGL, drag the OpenGL slider back a click to the left and try again.
Hello John,
Thank you. I have made the Intel scan. At first it looks that all is updated and maybe they are, but - in small letters - it actually says that Surface drivers are customized drivers, which should be updated by Microsoft. I have been assuming they are updated automatically, but I’m in the process of verifying that.
I haven’t crashed since the last time I posted (with files from scratch). So, I will keep your OpenGL slider in my pocket.
In any case, thank you.
N
