I need to have a proper repartition point on this surface but I don’t know how to do it with this shape.
I would like that points are on the blue curve is it possible ? And every sphere with the same distance
Thanks a lot
Attach you .gh file
pattern_sphere.gh (20.7 KB)
Is it ok ?
Hello
See this thread, it is a good one for a nice repartition
Thanks ! But it’s not a 2D surface
You can use Kangaroo, there are lots of example on this forum.
First slider gives a certain number of sphere then you move up the radius of sphere to make Kangaroo work. And last on the right is just for the radius of spheres.
pattern_sphere Kangaroo.gh (20.9 KB)
Thank you ! I don’t know Kangaroo I will read some topic on that
If you wanna extract surface points like they are aligned, I guess the steps are inevitable . I think if look at this , you get what I mean :
I would just create a second surface, create a grid on it, and then project/cut the points. You can freely move the surface until you find a good cut. Doesn’t even require GH, works with history as well.
The Kangaroo solution looks nice, but I guess the center is a bit odd. Such solution were often rejected. In my experience, the solution with most equal distribution and a clean cut looks best. Occasionally, I manually transformed some points the get a better outline. If you are also responsible for the surfaces, I would also consider slight variations to the boundary if necessary.
