These are some amazing results… Very exciting!
Can you share the Porsche scene for reference?
Curious how intel Macs are performing.
The newest RH8 WIP is still not producing any renders on my machine, as posted on my question above.
Not even on CPU?
No, only the “transparent” image posted above. I am clearly missing sth here…
At least with metal the transparent image is rendered 5-6x faster.
I should note that Rendering also did not work in the previous RH8 build.
Oh, so Raytraced works, just not the _Render command?
grab the latest release… that problem was fixed recently.
I am on the newest release (Version 8 WIP (8.0.23186.12306, 2023-07-05))
Exactly
odd… working here on the same version…
post your systeminfo?
Rhino 8 SR0 2023-7-5 (Rhino WIP, 8.0.23186.12306, Git hash:master @ a1ea879a58479b90068dee6bbb99c5b5c1622775)
License type: Educational, build 2023-07-05
License details: Cloud Zoo
Expires on: 2023-08-19
Apple macOS Version 13.4.1 (Build 22F82) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro16,1
Language: en
AMD Radeon Pro 5300M OpenGL Engine (OpenGL ver:4.1 ATI-4.12.7)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: AMD Radeon Pro 5300M
Displays: Color LCD (302dpi 2x)
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (2048 x 1280 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.intel.driver.EnergyDriver (3.7.0) 35E739F9-BF6C-3024-A67C-750711B3FB64
com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
com.paragon-software.filesystems.ntfs (149.8.15) B3791A17-53DF-3B03-9FF5-298D092ECF8C
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/rudolfneumerkel/.rhinocode/python3.9-30/libpython3.9.dylib
/Users/rudolfneumerkel/.rhinocode/python3.9-30/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/libtbbmalloc.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp "Datasmith Exporter" 5.0.2.0
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp "RhinoRoslyn" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp "RhinoCPython" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23186.12306
Just to be clear, this is the result I am getting:
@rudolf.neumerkel I can repeat the behavior you are seeing on my i9 MPB, completely blank renderings in both CPU and metal mode. Raytraced working as expected.
I logged this bug a while back, I added this thread
RH-73275 Rendering on Mac: blank image
Thanks!
