Rendering blocks - Material not showing
I am trying to render a scene with blocks. The wooden table shows up fine and is a block. The round rail in the middle is also å block but the material i configured in the block file is not showing up?
Materials for blocks have to be edited in the in place block editor (double click the block) and the change saved there for it to update. Is that how you edited the block’s material?
I use blockEdit command. File opens in a new window and I define the material there. As I did with the table. Donow what is the issue…
I figured it out. When inserting a new linked block it must have the layer style set to reference. It was set to active
