Render change to vray
Hey :wave:
I was trying to change render in rhino 8 to vray but it keeps change it back auto to rhino render.
I do _setcurrentRenderplugin then in command bar give me the ID and set rhino render again. at the beginning gave me gui license error but i solve it by making license offline but still cant change it and now no error popup for me.
Appreciate any helps.
Hi Koutaiba - does it work to set this from the Render menu > Current renderer? If you get a license error for Vray, I guess I would contact Vray tech support-
https://support.chaos.com/hc/en-us
I tried to do it from option-render-current render- vray for rhino.
But when i press okay and close option window it show on command bar that rhino render is the current one. I will try to contact support team.
Thank you for your reply :pray:
