I don’t now why I can’t switch VRay5 as Current Render Engine.
While I’m changing it from Tools, Rhino says: “Comando: _ImpostaPlugInRenderingCorrente
Comando sconosciuto: _ImpostaPlugInRenderingCorrente”
Is it possibile to solve the problem rapidly? I’m using a trial version of VRay and I’m loosing day of trial.
Thank you
Sincerely
The _ before the command name means to execute an English command with that name. Since there is no _ImpostalPlugInRenderingCorrente English command (but probably Italian one), either drop the _ or switch to English UI.
Hello @piergiorgio.marvaldi,
Does _SetCurrentRenderPlugin "V-Ray for Rhino" work for you?
If the issue persists and you are not able to set V-Ray as the active renderer, please reach out to support@chaosgroup.com , refer this forum thread and also request a reset of your trial period.
@Peter.Chaushev Since V-Ray and Bongo 3 doesn’t work together I setup a button to load the needed plugin but I can’t set the render plugin per script. Do you have an idea how to fix it?
I believe (you didn’t show the whole command log), that you’re calling SetCurrentRednerPlugin while another command is still running. Apparently SetCurrentRednerPlugin cannot be called transparently.
Please make sure you’re calling !_SetCurrentRenderPlugin "V-Ray for Rhino" - that will cancel any running commands
