Unable to make vray render the current render in rhino 8
hi,
I can’t set the render engine to Vray it’s keep the render set as rhino render
You should change render engine in Rhino settings, and restart (Rhino).
Normally a restart should not be needed, if Vray is enabled and loaded.
Are you saying from the menu, Render > Current Renderer > clicking V-Ray for Rhino does not work?
If so, pls run _SystemInfo and post back the results
this is what I did, and it’s go back to rhino render every time
‫בתאריך יום ה׳, 7 בדצמ׳ 2023 ב-12:13 מאת ‪davide76 via McNeel Forum‬‏ <‪notifications@mcneel.discoursemail.com‬‏>:‬
Hi
Mind that V-Ray 6.10.03 is compatible with Rhino 8 BETA, not with the official release. Rhino might check that and revert your change.
Just guessing, though
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, build 2023-11-21
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
‫בתאריך יום ה׳, 7 בדצמ׳ 2023 ב-12:32 מאת ‪Nikolay Bakalov via McNeel Forum‬‏ <‪notifications@mcneel.discoursemail.com‬‏>:‬
Hello
Nikolay Bakalov already mentioned, V-Ray 6.10.03 only supports the beta version of Rhino 8. I understand our download platform’s premature adjustment to the Rhino version numbering caused confusion. Apologies!
Minutes ago we released V-Ray 6.20.00 - it comes with Rhino 8 support and is available for download here:
https://download.chaos.com/?platform=51&product=47
Kind regards,
Peter Chaushev
I have installed Rhino 8 (final version) and Vray 6.10.03 and everything works normally, plug-in recognized and installed correctly (maybe because I also have version 7 of Rhino installed? I don’t know…).
This is logged here: RH-78745 Selected render engine in document properties > Render does not stick
I just Install it. it does not work yet
‫בתאריך יום ה׳, 7 בדצמ׳ 2023 ב-15:11 מאת ‪Nathan ‘jesterKing’ Letwory via McNeel Forum‬‏ <‪notifications@mcneel.discoursemail.com‬‏>:‬
The bug is logged, but not yet fixed…
I was able to fix this issue by changing the current renderer through the toolbar on the top of the screen. Render>Current Renderer>Vray for Rhino
Hope this helps!
by the way in the initial post, the ID of V-Ray is wrong:
_SetCurrentRenderPlugIn e8cfe179-b60c-411a-8416-62a893334519
Still having the original issue of the current renderer not updating when done through the options menu - but this works!
