The camera position in Rhino render does not seem to be aligned with the viewport camera. Is there a way to correct this? If the object is centered in the Perspective viewport, shouldn’t it be centered in the render?
This is already fixed. The bug was RH-64837Rendering Cycles: Rendering resolution larger than the viewport changed the view. A SRC went out before a build was created with the fix in. I believe a newer 7.8 SRC was created. The final 7.8 will go out soon - we’re waiting on some localization to be finalized.
