Hello all, I am a new user for Rhino Inside. When I create an item in Revit using Rhino, Wall or shaft opening for example, and unpin and modify in Revit. Is there is way to retrieve the element as it was created by the Grasshopper Component. I tried recompute but it did not work.
Hi Karim,
Welcome!
I changed the post to the Rhino.Inside - Revit category.
You can repin, but depending on what you were doing the Grasshopper definition may overwrite your changes.
For example, a change to the Comments Parameter will not be affected, but if i change the size or type of the wall it would be reverted back to the grasshopper definition controlling that aspect.
Thanks a lot Japhy. Really appreciated. ![]()
