Hi, since the last update I have noticed some files crashing on opening.
Has anyone else experience something similar?
The workaround is to open an empty rhino file, and from there, File>Open and the files open fine. Which makes me thing there is something clearly wrong with the update.
If you can share a file that crashes Rhino, we can give it a try and see if we can repeat the crash. If we can repeat a crash, we should be able to fix things pretty quick.
Hello- I am looking at the file now - so far no issues opening or anything else; I see there is some Enscape user data - what happens if you disable Enscape in Options > Plug-ins page, close Rhino, re-open it and open this file - any different?
@ShynnSup - thanks, got the dump file - and yes disabling Enscape as you show and then restarting Rhino would be the test for that plug-in, but looking at your image above, I would also disable the other plug-ins shown there, again with a restart of Rhino, and see if there is any change. If not, I’ll log a bug with the files you’ve sent.
@ShynnSup thanks for sending the file. I can reproduce the crash here when opening, importing the file works. (I did not try the workaround you found, since I was testing this on Mac) RH-82377 file crashes on opening
